Spots inside Pecan
Started by Poquo, December 18, 2019, 10:26:34 PM
Poquo
Cutting some Pecan came across these spots in the cut , don't appear to be metal feels like coarse sand in the spots . Dulled the blade real quick , anyone run across something like this before ?
2015 Woodmizer LT40HD26
Fungal stain from ambrosia beetles holes.
Poquo
Thanks , this was the second cut with a 4 degree blade when it got there it sounded like it hit metal . The spots felt like they were full of sand .
offrink
terrifictimbersllc
Often one can look to the exact point where the cut quality changed, for the reason.
dustintheblood
This is hickory (bitternut) that was one of my first bowls.  I love the spots
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
SawyerTed
How deep in the tree were the spots?
Ambrosia beetles penetrate deep.
Poquo
The spots were 2-6 inches in they were in a crotch of where 2 big limbs met the main trunk .
Ambrosia beetles love pecan logs.  If a pecan log lays around after felling for even a little while, the ambrosia beetles will sniff it out.  Here is some pecan from a log that laid on the ground over the course of a summer.  You can see the black stained ambrosia beetle holes.
Customers also love Ambrosia Beetle stained Pecan lumber.  smiley_thumbsup
