harvesters
Started by notchjohnson, March 27, 2019, 08:06:27 PM
notchjohnson
am thinking of buying a wheeled harvester and was wondering if some one could tell me the advantages and disadvantages of a telescoping style vs a boom style
wannaergo
If you are talking telescoping like a ponsse, I think the parallel style is just a lot more simple, and lower maintenance, with less moving parts.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
barbender
We're moving towards the parallel cranes on our harvesters, for the reasons wannaergo listed. Less moving hoses, no hose reel, no slide pads. It also comes down to matter of preference, I've only ran the sliding cranes so I can't compare. A lot of guys don't like the parallel crane when they first run one, but then come to prefer them. I do know of one guy that that bought a machine with a parallel crane, hated it, and traded cranes with a guy that had a slider.
Riwaka
Ponsse  label them - sliding boom crane (C6 and C5) and Parallel Crane (C55, C50 and C44+). My preference would be for parallel crane.
Have you done the cost comparison (wheel vs track machine) or is there an environmental instruction, contract clause why you must run a wheel harvester?
Tigercat have the 1135 and 1185 wheel harvesters. I think someone was 'joking/ logger's fantasy fiction' when they mentioned recently an 1155 wheel harvester in the future.
Tigercat LH830 (track leveller) with squirt boom and sp harvester at 18000 hours.  (drive oil volume around 8 gallons vs around 60 gallons on some wheel machines)
SP861LF on Tigercat LH830 - YouTube
wannaergo
Riwaka, tigercat is actually building a mid sized wheel harvester,  I believe 1165. The first one will be rolling off the line within a month or so.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
chevytaHOE5674
After thousands of hours on a sliding boom Ponsse it got to be second nature. Had our fair share of hose/wiring issues in the boom, also bent a few extension cylinders. Later on I ran a Jd with a parallel crane and I felt like a fish out of water.
Having said that once you get used to either it will be 2nd nature. The parallel cranes don't have slide pads, chains, hose/wire spools, and a long cylinder to care for which is a plus in my book.
Skeans1
For thinning my choice would be a parallel just for the fact you can tilt the base of the crane around a tree to access another one behind without damage.
Corley5
How do they compare purchase price wise?
wannaergo
If I remember correctly, our parallel crane was $10k cheaper than a slider
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
barbender
Wannaergo, you have an H8 on that parallel, don't you?
wannaergo
Yessir. We absolutely love it too.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
barbender
Cool! I was pretty sure your machine was set up with an H8, me and the local Ponsse salesman (a friend) were debating that at our last logging show. They had an Ergo 8w with a sliding crane and H8 head. He thought you had to use that crane to hang an H8. I will correct him😁
wannaergo
Actually when we got ours, they wouldn't put an H8 on a slider crane, only the parallel. For a short time I had the only ponsse on planet earth that didn't have any extendo boom.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
Riwaka
