Roadside logging
Started by sprucebunny, April 04, 2019, 04:14:55 PM
sprucebunny
This has to be tough on tracks.
beav
Prolly rough on the road too! Looks like oil leaks in the first picture
sprucebunny
The road is pretty well wrecked already. Delaminated and some whopper holes they filled in February . US 302 in Fryeburg.
beav
Ya my memory gland says that road was rough around the turn of the century when we took it on a m/c camping trip to moosehead lake. Also like the roads around here- especially this time of year
kiko
I was unaware that a jd track / rubber tire buncher without leaks exist. Leaks are not an option they come as standard equipment.
sawguy21
 :D That is hard on roads and equipment.
LeeB
Really quite surprised the state hasn't fined them for have tracked equipment on the road.
barbender
SB, those tracks aren't bothered by asphalt any. Driving on asphalt in cooler weather isn't much different than driving on ice, you skate all over. No traction=no friction=no wear. Things often don't turn out as well for the asphalt, though. At any rate, that is a beautiful stand of white pine they get to cut, albeit with some challenges😊 Even being a logger myself, I don't like to see those beautiful old stands of White Pine come down.
nativewolf
Quote from: LeeB on April 05, 2019, 12:37:25 AM
I'd guess the state might have been involved in letting them do it.  Can you imagine how many of those trees have blown over there.
Liking Walnut
sprucebunny
The trees have been marked for a few years. I imagine they are going to (have) to repave the road this year. Any damage from equipment will be minor compared to what plowing did this winter !!
It is a very nice stand and hasn't been falling over very bad but you can see a few are dead and probably shedding branches.
The wires right there have to make it exciting for the buncher guy !!!
snowstorm
since the state or town own that land they a likely working for them. the road riteaway will be at least 66 ft
Skeans1
Really it's not that hard on the pavement unless you turn on it, yes it's single bar grousers but you're just going back and forth on the surface. You'd be amazed on how often they walk a 100k shovel out on the road to help push a tree that's hard on the road.
Should see a grapple skidder go on a paved road. They have that thing in high gear. ;D  I have seen that when the state is going to redo the road.
GRANITEstateMP
Quote from: sprucebunny on April 04, 2019, 06:30:46 PMUS 302 in Fryeburg.
Sprucebunny,
  Is that the section of RT.302 right past the School, near the turnoff to the fair?
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
sprucebunny
It's between the NH state line and the little hill before town. Near the new info center.
GRANITEstateMP
Ok, that makes sense.  Plenty of tall pine along that road, but I always think of the Fair before the trees!
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
Riwaka
There are crews that a doing a lot of road/ street tree work that have even sizeable machines on rubber pads or clamp ons , rubber tracks put down boards/ mats etc.
https://www.cautrac.com/product/clip-on/
Ken
Beautiful trees.  I'm guessing that buncher has already done a lot of walking on hard surfaces as the grousers look quite worn.  I'm curious as to what took the big chunk out of the engine compartment in the top left hand corner of the last picture.  Looks like he got into a fight with another hot saw
GRANITEstateMP
That's just a bug bite Ken.  Our Mosquitos get pretty big up here ;D
Hakki Pilke 1x37
Kubota M6040
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
