What to do with this?
Started by D6c, June 19, 2019, 08:49:30 AM
D6c
Found this elm tree that had split and left this image.
Any ideas on what I should do with it?
Southside
Put pumpkins around it and charge folks to take a photo in front of it at Halloween
White Oak Meadows
WV Sawmiller
   I think I'd cut the tree about the top of your picture then cut the stump off as low down as I could then I'd slab it several inches deep to preserve that image then go get the pumpkins. Nice find.
Crusarius
I was thinking add a goatee and a hat :)
btulloh
Looks like a tree from the Harry Potter forest.
Put a trail cam there and see what it does at night when nobody is around.
HM126
Woodpecker52
Leave it for the woodpeckers they need all the help they can get.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
kelLOGg
Old Greenhorn
Looks like the Ents are preparing another march.
RAYAR
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (431,000 Km)
Solomon
Quote from: btulloh on June 19, 2019, 09:39:48 AM
You must be younger than I, I was going to say a tree from The Wizard of Oz.
Six of one, half dozen of the other I suppose.
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
