would these rollers work well for using around lt 40 saw mill ?
Started by gdaddy01, June 21, 2019, 10:13:30 PM
gdaddy01
Note from Admin:  Pics must be in Forestry Forum Gallery.  Please read rules.
Crossroads
I'm pretty sure I would be able to get some use out of them around the sawmill. Especially with the board return in place.
redbeard
 put mine on wooden frames too handle the heavy stuff been working great, it's nice not having too lift too much.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Southside
Yup, I have around 130' worth of them between stations, in feed, out feed, etc.
White Oak Meadows
gdaddy01
thanks , I like the ideal about the wooden frames , I think I might have to buy them , wants 400 for three of them , how does that sound on price ? 10 feet long .
Southside
I have paid between $7.50 and $10 / foot, but I was not in a hurry for them and passed on plenty more that were higher priced.
White Oak Meadows
redbeard
400 for 30' is a bit high
They do look heavy duty I like the fixed rollers best they don't pop out if a board hits them wrong .
There easy too take out and oil them up.
If you do look at them make sure the springs aren't jammed up and there easy to remove. So you can maintenance them.
rooster 58
The rollers are to light for heavy cants or ties. I had roll cases similar to that. The BBC rolls eventually got dented so bad they hardly worked.
gdaddy01
I am sorry if I broke some rules , I did not intend to do anything wrong . I guess maybe I should just read and not post .
Don't fret and don't stop posting.  The proper way to post pictures is found here:  Updated Photo Posting Tutorial in Technical Support Topics
If you need help, just ask.  :)
Bandmill Bandit
I got 24 feet of roller table with 2 inch rollers every 3 inches for $50 bucks.
This is the first table I built with the rollers spaced every 24 inches. I am planning to build a couple of short tables but haven't got there yet as the need for them in not real pressing.
