Staring the new sawmill shed for the LT 40
Started by Hackeldam Wood Products, April 16, 2019, 06:47:09 PM
Double doors on entry side. Need to trim and install the hinges. The heat beat me out today. Have a great Independence Day weekend!
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
My old knees told me the roof is on!
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
New Woodmizer tool in the sawmill shed. Trim , battens and inside shelving and it will be finished. Then I'll strat the addition to cover the mill.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Bruno of NH
Quote from: Bruno of NH on July 07, 2019, 07:48:29 AM
Looks great
Thanks. I'd like to tackle some timber frame like yours someday when I have the time.
Also I had some slightly wavy pine with the 7 carbide. The blade still seemed sharp. I have about 50 hrs on the mill so I am going to check the drive belt tension.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
jbjbuild
Looks great! Really like how it turned out.
Woodmizer LT35HD, John Deere 790, Logrite Cant Hook
Changed  the oil and filter, tightened the belts and moved her to her new home today. Has 56 hours on it.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
wayback40
Looks great.  Did you dry the lumber first or put it up green?
Wood-Mizer LT15
Quote from: wayback40 on July 11, 2019, 11:23:27 AM
Thanks. It was stacked and stickered for a few months. There is some shrinkage after it's up in the hot sun. I'll wait a few weeks to put on the battens.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
samandothers
Looks really nice!
If the blades are sharpened ones could you add a strip of wood to top of brackets to protect tips of teeth?  What will you finish it with or will you leave it natural?
Look forward to your shed build.
Quote from: samandothers on July 12, 2019, 10:29:46 AM
Looks really nice!
Thanks. I like a ceder colored stain or Australian timber oil. The blades tips are o.k. on there.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
