Toughest post to plate joint?
Started by Satamax, July 17, 2019, 03:36:30 PM
Satamax
Hi everybody.
Well, due to planning permission constraints, i want to build myself a "moveable" deck.
Basically four 8"x8" posts, about 14ft high. Four "plates" Or end joists, you might call these. These will be 4x12" 16" and 20" long 13 3x8" joists.  of the short dimension 16' long. With 1" 3/4 decking on top.
All this has to be able to be lifted with my crane of 24T/M
So i will wind brace it. But, what is the best joint i can use?   I was thinking full lap for the plates,  shouldered vertically into the posts "forks"  As it is done for the ridge beam on a king post's post.
A bit like this
But there's four corners. And the plates are shaved each side, of a 1/2 inch or so, to make shoulders which lock on the post outer faces.
What do you think?
This would be the traditional way in France.
French CD4 sawmill. Mecalac digger, with grapple. Self moving hydraulic boom crane. And a Brimont TL80 CSA.
Don P
Simpler joinery and decreased spans?
Satamax
Quote from: Don P on July 17, 2019, 10:03:30 PM
Thanks a lot Don. Well, i can't really do decreased span, width way, because i want to park my car underneath :D
As well, it should be liftable with the crane, so real stiff. Also, it has to be "clean" as it's my job too. mostly balconies, stairs, roofs. Bit of stick framing, bit of timber frame. I'm all tooled up.
