Using Plastic Strapping For Lumbee
Started by mddillon78, August 28, 2019, 05:45:45 PM
mddillon78
How many of you guys use poly strapping for lumber?  I just started using it and it seems like it will work well.  Makes it easy to move the stacks around as well.
Can You Use Plastic Strapping for Lumber? (Poly Strapping Strap Pac) - YouTube
Michael Dillon
Dillons Woodworks - New Hampshire
Custom Sawmilling and Woodworks
Dillonswoodworks
Dillonswoodworks - YouTube
SawyerTed
I do.  The poly bands work great.  I have strapped stacks, loaded them for delivery and dumped the whole stack like builders supply folks do.
The first stack broke the bands.  I've since learned a better technique.
mddillon78
Thanks for the feedback.  What did you do differently?  What was it you learned from that issue?  Thank you!
Michael Dillon
Dillonswoodworks
Bruno of NH
mddillon78
Thanks Bruno.  It's working good for you?  Do you use the ratchet tensioner or the pull type?
Michael Dillon
Dillonswoodworks
SawyerTed
I dump the stack slower and I make sure it is on 4x4s or 6x6s so it slides easier.  An 8' stack is harder to control than longer stacks.
Bruno of NH
PAmizerman
I use woven strapping. It is tough stuff. Easily reusable. And easy to store and handle.
Hydraulics everywhere
Woodmizer edger 15hp electric
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
mddillon78
Wow! That looks real strong.  Where did you get that stapping?  Can you use the same tensioner?
Michael Dillon
Dillonswoodworks
D6c
That looks like Kubinec strapping.... I've been using it to tie up stickered lumber.  Regular strapping tensioner works fine.  I go back every few days an retention the stack as the lumber dries and shrinks, something you can't do with plastic pallet strapping.
PAmizerman
@mddillon78 I get my strapping from strapping products.com
I get the 3/4 inch 3500 lb Break strength
WM bms250 sharpener
WM bmt250 setter
PAmizerman
I use the ratchet style tensioner. I got mine off e bay
I got the cheapest one available and had very low expectations but thought for $20 why not? I've been using it for over a year now and it's still working great. I just give it a shot of oil every once in a while.
WM bms250 sharpener
WM bmt250 setter
Brucer
I used Kubinec brand poly strapping for my slab bundles. 3/4", 2700 pound tensile rating. The stuff was way better than the 1/2" steel strapping I tried at first.
I could dump the slab bundles from a height, pile them on each other, dig a bundle out from the bottom of a stack -- and never broke a strap.
Bruce    LT40HDG28 bandsaw
