sawing 1 1/2 boards?
Started by yellowrosefarm, May 07, 2020, 10:36:17 PM
yellowrosefarm
What do you guys do when sawing 1 1/2 lumber? I have a 4/4, 5/4, 6/4, 8/4 scale on my mill but need to cut true 1 1/2" .
VooDooChikin04
6/4 is 1-1/2" right?  Then add blade kerf..   Atleast thats what I thought
WV Sawmiller
   I use my SimpleSet and set it for 1-5/8" drops to account for the 1/8" kerf. My cheatsheet has the starting point for the 4th face so I end right on my mark.
   Then again - that is the same answer I will give you for any thickness. SimpleSet and Cheat sheet. Good luck.
yellowrosefarm
6/4 scale cuts 1 3/4,  5/4 1 3/8  Mill is an old LT40
Wintergreen Mountain
   I made up a 7/4 scale on the side of my gauge. When I saw 1 3/4" (7 /4) the wood after it dries is very close to 1 1/2" western cut.
  2 x 6 are cut 1 3/4" x 5 3/4"
1920 Ford 4x4 tractor, forks & bucket. 2010 36" Turner Mills band mill. Cat-Claw blade sharpener. Cat-Claw Dual Tooth Setter. Cat D3 crawler dozer. Cat 215c excavator, Ford L9000 dump truck. Gardner Denver 190 portable air compressor. KatoLight 40Kw trailer mounted gen set. Baker M412 4-head planer.
barbender
You must have a hardwood scale. My scale has hardwood on one side, and standard scale on the other. The standard scale is true sized (4/4 is 1", 6/4 is 1 1/2" etc.) Maybe you could order a new scale from WM?
alan gage
I bought a 6/4 scale from Cooks. My impression was that it would saw 1 5/8" boards. I'll find out for sure next week.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
