Hollow Pecan
Started by Sixacresand, May 09, 2020, 07:37:34 AM
Sixacresand
My sawmill buddy and I played around with cutting oval cookies out of a short hollow pecan logs, the part I usually discard to the burn pile.  He is a wood artist, for the lack of a better term.  He deals with filling hollows and cracks with colored epoxy material, .  He sells for high dollars on the internet and local craft fairs.  He also uses the same philosophy as WDH, make everything small enough to fit in a woman's SUV.  :D
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
WV Sawmiller
  Those aren't cookies - they are donuts. :D I have some made from walnut and the advantage is they are less likely to crack than normal cookies.
Sixacresand
Quote from: WV Sawmiller on May 09, 2020, 12:48:34 PM
That is good to know.  We talked about what to if it started cracking.  Thanks
It works!  Men are cheap and indecisive. Women are smart, decisive, and know what they want.
Brad_bb
that's actually a good idea- doing epoxy fills of donuts.  You could do some interesting fills.  Don't discard hollow logs.....
Texas Ranger
Quote from: WDH on May 10, 2020, 08:56:54 PM
OMG!  We need to open up the economy and do away with the quarantine, not saying Danny is wrong, but to admit it? Danny, take a couple of deep breaths, dig out the shot gun and go out and fire a few.  Hold on, brother, it is getting better!
