Inland Marine insurance costs
Started by DPatton, June 17, 2020, 07:04:43 PM
DPatton
What kind of rate per thousand are you paying on your inland marine insurance policy? I recently received a quote for inland marine insurance on my sawmill and associated tools. The rate is $52.50 per every $1,000.00 of total insured value. This number seems high to me so I could really use member advice to make a sound determination. Your input greatly appreciated.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
Cjross73
I'll have to check to be sure but Farm Bureau NC is charging me $12-$13 per thousand
LT40, Stihl saw, Old green tractor
Mossy Chariot
I am paying the equivalent of $25.52 per thousand through Berkley.
Tony B
LT35HD, Riehl Edger, Woodmaster 725 Planer/Molder, Nyle 53 Drying Kiln, WM BMS 250, WM BMT 250, T750 Bobcat, E50 Excavator, Kubota 3450, Wallenstein Skidding Winch, Vermeer BC1250 Chipper, Stihl 250 & 460, Can-Am Defender
terrifictimbersllc
Liberty mutual $15.74/thousand on my new LT70 super.
barbender
SawyerTed
Mine is $285 per year for the sawmill and associated tools.  Ironically, or maybe not, it's the same for my tractor.
DPatton
Quote from: barbender on June 17, 2020, 08:30:52 PM
Are these prices per year?
barbender, great question and I should have clarified that in the original post. My quote of $52.50 per thousand is for an annual premium.
DPatton
Quote from: SawyerTed on June 17, 2020, 08:33:02 PM
SawyerTed, now that sounds real reasonable. My quote for inland marine coverage was $1,706.00 for $32,500.00 of total coverage on my sawmill and associated tools like chainsaws and blades. Me thinks Somebody's looking to get rich off of me.
DPatton
Quote from: Mossy Chariot on June 17, 2020, 07:37:32 PM
Mossy Chariot, thanks for your input. Can you please verify is that an annual premium?
DPatton
Quote from: terrifictimbersllc on June 17, 2020, 07:54:37 PM
terrifictimbersllc, is that an annual premium cost?
DPatton
Quote from: Cjross73 on June 17, 2020, 07:22:13 PM
Cjross73, same question goes for you.
terrifictimbersllc
Yes, per yr, total replacement with 1000 deductible and a bunch of side coverages. I don't know where I would rent an equivalent machine but it would cover that too
Sixacresand
I was disappointed that the big name insurance companies operating in Georgia would not insure a sawmill.  I didn't know about Liberty.  It might be time to "bundle and switch".
Mossy Chariot
Yes @DPatton that is per year with a $1,000 deductible.  I was shopping for General Liability for the sawmill, which was not easy to find, and added Inland Marine with the GL.
Tony B
Cjross73
Mine is per year ss well. Pretty good policy,  even covers mysterious disappearance... I've switched everything to farm bureau now
WV Sawmiller
   I think I pay about $650/yr for $2 million worth of liability and I think they wanted about that for $30K inland marine which I thought was excessive for the amount of coverage so I declined and just got the liability. It would be painful but not catastrophic if I lost the mill but I could stand it but could not for the liability plus some customers and such require proof of insurance to saw or do demos and such. Good luck.
Redhorseshoe
$450 per year for $45,000 worth of coverage.  That is for my mill and tractor, purchased through Country Financial.  I also have liability through them so I think I get a little break on the inland policy.
I got one quote from a company out of Texas, they wanted over $1,300 for GL and nearly $2,500 for the inland policy on my mill (LT15) alone.  I think you just need to shop around a bit trying to insure these things.
boonesyard
$600/yr for $1,000,000 GL
$1,013/yr for $100,000 inland marine
Nationwide
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
