SpaceX Log Arch
Started by firefighter ontheside, August 02, 2020, 05:40:40 PM
Did anyone see how Space X gets the crew dragon capsule onto the ship.  Its a log arch.  Someone might be able to recreate this hydraulic arch for their own use.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
I watch every second. Elon probably got the idea here. ;)
barbender
A forum member should see if they can use it in between Space-x retrievals😂
beav
Will the capsule be re-used? It seems the salt water would wreck it?
Elon is changing our future in many exciting ways.
Sixacresand
NASA is using sawmill and log technology.  I''m guessing parbuckling was ruled out.   :D
"Sometimes you can make more hay with less equipment if you just use your head."  Tom, Forestry Forum.  Eleventh year with a LT40 Woodmizer,
Yes it will be re-used.  I think they said as much as 3 months to put it back in service.  They said they will clean the outside, but some of the scorch marks will be left, sort of as a badge of service.  Its like us firefighters, we like to leave burn marks and smoke stains on our helmets.
I know they tested a lot before they put all of this SpaceX stuff in service.  Perhaps they tried parbuckling the capsule up on the ship.  They talked a lot about the astronauts being likely to vomit after landing.  Perhaps rolling the capsule onto the deck violently was deemed less than helpful.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
DbltreeBelgians
I watched it all and the log arch on the back of a trailer was the first thing to come to mind.
Make a great aqua-logging setup on the Great Lakes.
Brent
mike_belben
Looks like it could almost move a log big enough for matt cremonas mill too.
Praise The Lord
Thats true.  I bet it will lift a pretty big log and hes got a pretty big mill.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
John Mc
