returning to your original search
Started by bitternut, July 22, 2005, 07:59:54 AM
bitternut
 I was doing a search on chainsaw winches and after viewing one of the results there does not seem to be a way to go back to the results of your original search. When you hit the back button you get a page expired notice. Am I doing it wrong or what?
johnjbc
When you want to look at an item right click on it and choose open in a new window. When you are done reading it just close it and you will still have the search results page open and unchanged.
LT40HDG24, Case VAC, Kubota L48, Case 580B, Cat 977H, Bobcat 773
Also, try hitting the back button a second time after getting the "page expired" notice.
bitternut
Boy, opening in a new window is what my wife showed me a long time ago and I have always just used the back button. That open new window trick worked real easy. For some reason the back button would not work no matter how many times I tried it. I'm not going to tell her I didn't listen to her. She already knows I have husband ears. Thanks for the tip guys.
