Novice has question on bar/dl for dolmar 5100s
Started by Bobtray, December 22, 2020, 10:12:07 PM
Bobtray
I picked up a dolmar 5100s that had a original 18" bar that was marked "Dolmar PQ 3/8 64", the bar is shot with tempering colors and burred real bad.
I bought a cheap 18" Trilink bar and the paper label said for dolmar 5100s, it is a .325 .50 72DL,,,, I put it on and only 3 drive links mesh on the sprocket, the 4th link isn't close to meshing,,,, just for kicks i tried it and shut it down after a few revolutions, I could tell by the noise, it ain't right.
Odd to me that the cardboard list the 5100s as the saw that the bar is for, but it sure looks/sounds like it won't work. Can't rotate chain by hand, only can move it about 3 drive links.
I went to Oregon site and entered the model of saw, 18" bar and it came back with 3 drive link options, a .50 3/8 68, .50 3/8 64 and .50 .325 72.
In my mind I can't see that sprocket covering a 64, 68 & 72 drive link chain,,,,, maybe 2 different ones but not 3.
Am I doing something wrong?
Is possible a sprocket was changed?
Please help,,, and thanks!
sawguy21
Welcome! You have come to the right place. The problem is you are trying to fit .325 pitch chain on a 3/8 sprocket, that won't work. The best bet is change the sprocket to match, I think you will be happy with the results. You can use 3/8 chain but the saw needs to rev.
Bobtray
Thanks a zillion,
The new bar is mis-labeled, it said for 5100s, BUT didn't say you need to change sprocket.
I did find a reasonable one on FEEbay, it's a "Forester brand.
Would a 3/8 .50 with 68 drive links work? (Original had 64)
Thanks again!
coppice
It wasn't mislabeled. It just happens to be a .325" pitch bar and you are setup for 3/8" chain.  The saw could just as easily have been wearing a .325" rim to begin with.  The packaging was perfectly accurate, it just assumed some very basic knowledge on the buyers part.  The saw you have can accommodate either - the bar studs and oiler hole line up, therefore the bar fits - so long as your drive sprocket, chain, and bar match relative to pitch, and your chain and bar also match as to gauge.
3/8" .050 68dl works fine, but your existing 64dl chains will be too short.
ButchC
As I remember those 5100 saws could be had either way, 3/8 pitch or .325. . On saws that size I much prefer .325 pitch chains. You you need to change both the sprocket and purchase the correct chain to use that bar.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
sawguy21
3/8 X 64 is not common in North  America but I have seen it. That is the European 17" bar that came with some saws.
Bobtray
Thanks so much guys!
A real wealth on knowledge on this site!
I just ordered one off FEEbay that was a 3/8 pitch so I can use same sprocket.
The seller "sound" like he knows the problems of a 64 drive link bar/chain.
THANKS GANG!
This is how he posted the auction:
**  THIS LISTING IS FOR .050 GAUGE 18" BAR WITH K095 MOUNTING AND A .375 (3/8) pitch .050 GAUGE 68 LINK CHAIN.
This is a replacement solution for Dolmar saws that had a 64 link bar setup that is NLA - No longer available.
**This is also a solution for many of the 58cc China chainsaws using 3/8 pitch.
