Changes
Started by Jeff, December 12, 2000, 06:10:23 PM
0 Members and 11 Guests are viewing this topic.
Im sure it is. Ill look. I probably should make a post somewhere and let people know why im not on the ball lately so they dont just think im blowing stuff off
Old Greenhorn
Quote from: Jeff on January 02, 2020, 05:20:24 PM
Fixed
You are such a whizz kid!
Seriously, I just read your note about whats happening and I feel terrible for you. You deserve a diagnosis by now. Had I known you were still dealing with that pre-Christmas thing I would have never even brought this up. Jeff, I truly wish all the best for you and some speedy help for this mystery.
I want it brought up. :)  I appreciate that help.
Dustin
I opened the Finda-Data-Base, and if I click the link at the bottom to edit a record it brings up a login screen. I do not believe I have a recorded entry and maybe is why the screen does not change if I try to login. However, when I click the "Click here to add a new record to the database" nothing happens. I can open it in a new tab/window and it comes to the page to login in. When entering a username/password and hit enter, then get the error "There is no value for cgifunction".
Richardson Sawmill
'20 Wood-Mizer LT50HD Wide
Husqvarna 390XP and 450 chainsaws
Just getting started but already know I have an addiction problem.
@Dustin  carry over from secure server add.  Not sure if I got it. Give it a try
Dustin
@Jeff it now works for entering a new record but not if I try signing in as a member. It tells me the username is already used. Would I need a different username than what I sign into the forum with or should it be the same? If I try to sign in as a member I get the first error of "There is no value for cgifunction".
Richardson Sawmill
You know his has nothing to do with your forum login correct?
Dustin
LOL no I did not. That might have been why I was on the struggle bus. Thanks for setting me on the right path Jeff.
Richardson Sawmill
