Log waterbars
Started by DeerMeadowFarm, July 20, 2021, 11:19:19 AM
DeerMeadowFarm
Looking for some help. One of the roads in my sugarbush is quite steep and the rain we've had in Massachusetts has made it clear that I need to get serious about water bars. The slope is quite steep so I will need many water bars placed fairly close together. I know water bars are not the number one method of erosion control but after researching on line and given my terrain, equipment and financial resources (my daughter is starting college this fall!  :o) I think I am kind of forced to utilize log water bars described here: https://www.fs.fed.us/t-d/pubs/htmlpubs/htm07232806/longdesc/fig20.htm
I have a couple of questions. I have mostly hardwood at my disposal; red oak, ash, hickory, cherry and maple (red and sugar). Is any of these better than the others? Are any of these completely not usable? Can the bark be left on or should it be removed?
Thanks in advance for your help in suggestions!
BradMarks
The old time ones I've come across look like they use cants in the roadbed, not whole logs fwiw.
mike_belben
Hickory and maple will rot extremely fast in dirt contact, especially with bark on.   Red oak lasts a long time with bark off. I dont know ash at all but from how fast guys say it turns to trash on the stump by EAB i think red oak would be my choice unless you had white oak, locust, osage or hedge.
For the future... If theres sufficient light on the hill then this is the most robust, adapted to all climates, flood and drought tolerant, unkillable erosion control grass i have encountered.  It will grow in a compacted rock driveway and will hold a hill together.
Echinochloa crus-galli
Praise The Lord
DeerMeadowFarm
Thanks for the info on the grass Mike. I planned on planting something; I just wasn't sure what.
peakbagger
Rubber razors are nice alternative if you can find some with scrap converyor belting.
DeerMeadowFarm
Quote from: peakbagger on July 20, 2021, 07:02:39 PM
This is what I'd really like to do, but finding the belting has been the issue for me. My BIL did this at his camp road in VT and it's awesome but he bought new rolls of belting but I can't afford that.
peakbagger
I just ran into this place https://www.repurposedmaterialsinc.com/index.php?p=catalog&mode=search&search_in=all&search_str=belting
I have not bought anything from them but they do have lot of interesting stuff including belting.
Price is right.
barbender
Check with a sand and gravel outfit. They usually have no shortage of used belting laying around.
It was common practice on forestry roads on the BC coast to use water bars. But those roads were crushed stone and gravel, not mud. There was nothing placed in the road, just an angled shallow ditch.
Plankton
I would just dig rhem if you have the equipment. Make the wide and shallowish so you can still go over them easy with a wheeler or a tractor. Should hold up for a long time if your not driving over them with anything super heavy.
mudfarmer
Don't have much experience with oak but from your list I would use black cherry and even possibly saw the sapwood off a la BradMarks. The sapwood of cherry rots fast but the heartwood will last years. Search the internet for "black cherry rot resistance", Purdue says "Decay Resistance
The heartwood of cherry is classified as resistant to very resistant to decay."
What Plankton is talking about they call a 'broad based dip' in most of the BMP publications etc.
© Skid-Er-Dun Slogging, a Delaware Limited Liability Corporation
DeerMeadowFarm
Quote from: Plankton on July 25, 2021, 09:08:40 AM
Yah, I think I'm going to try that first. I'm just afraid that the slope is going to be too steep...
RPF2509
Waterbars are required here in CA post logging on every skidtrail and unsurfaced road.  They are almost always made by equipment, infrequently by hand.  6" deep with minimum 6" berm.  Travelled roads use rolling dips which are generally wider more compacted versions of the above.  The key is to angle them about 45 degrees to the direction of the road to shed water downslope.  Extra rock on top of of the berm helps them hold up to heavy travel.  Don't use the road when wet if it can be helped.  Dirt/ gravel ones are easily fixed if rutted.  The steeper it gets the closer you space them 50' is minimum distance between (50% slope or greater)  300' maximum (flat ground).  Properly constructed and spaced, they are very effective in controlling erosion.
peakbagger
The waterbars on my lot were very aggressive to the point where I could drop a 18" culvert into them and still have a ditch on top. I have been considering filling them in with the rubber razors in place of culvert and keep a bit of a swale upstream. Its a steep sidehill road so my guess was whoever put them in figured might as well dig them deep. In at least one spot they didnt slab the slope and made a major washout that is still healing 30 years later.
mike_belben
What do you mean by slabbing the slope?
Praise The Lord
peakbagger
Cutting diagonally up a steep slope rather then going straight up it.
Treeflea24
I have a similar situation.
Rather than using logs im planning to use precast concrete parking blocks that you normally find in parking lots. Should outlast any log. they have two holes that you can use to drive 1/2" rebar stakes in to keep them in place. Theyre about 6' long and 6" high - depending on the type of traffic your trail has it may be a problem or require partial burial. You can move them with a wheelbarrow or dolley, two regular guys can lift and set them, it only takes one guy to kick and drag and slide one around. A local recycling place sells them for $10 each.
Just another idea to consider.
mike_belben
The problem is water is going to wash under any object you place in its path and blow out everything it can move.  As the gap increases under the log so will the velocity and thus the size of particle the water can carry away.
Once you disturb the ground the bury the object the next rain will probably take away half the backfill unless you compact the snot out of it and somehow get it stabilized.  Plus, how are you gonna drive over a slippery diagonal log or curbstone on a hill without getting launched off the side of the trail by it every few passes?
I really think deep dugout swales and agressive plantings of deep rooted weeds and grasses is the answer.  Stuff that spreads by rhizomes and stolons and that can hold up to continuual traffic without dying after its crushed by tires.  Find a spot in your yard with nuisance grasses that just wont quit.. The patches you always have to mow again first, and let them go to seed.
Goosegrass, cockspur/"barnyard" grass, bahia, dallis and crab are commonly doing that job here in TN. Once established youd need a nuke to stop these from coming back.
Praise The Lord
GullyBog
The best water bar i've seen so far is an I-beam.  But I doubt I could bring myself to do it if I had one.  It was a very nice place.
There might be a little dust on the butt log, but don't let if fool ya bout what's inside
