TJ differential ID
Started by Bjt, November 03, 2021, 07:05:30 PM
Bjt
O
 Need help identifying the differential housing on my 208E that has the 8 bolt hubs and rims with fixed spindles and a tag on the housing that says p75 or f75. The wheelbase is 8-10 inches wider (measurement made from inside to inside of the hub) than the older 230 I purchased for parts that has the bolt on spindles with pr76 planetary hubs and housings.
Firewoodjoe
Looks like a pr52 but I'm not certain. Call js logging parts and supply. He knows.
lshobie
Looks like the 52's on my treefarmer
John Deere 440 Skidder, C5 Treefarmer,  Metavic Forwarder, Massey 2500 Forklift, Hyundai HL730 Wheel Loader, Woodmizer LT40, Valley Edger,  Alaskan Mill, Huskys, Stihls, and echos.
Bjt
So does pr52 refer to the differential housing and planetary hubs together as one unit? And will any other heavier planetary hubs interchange with the 52? I know that the pr76 will not. Thanks
