LT 35 Head Cover
Started by widetrackman, November 12, 2021, 11:57:26 PM
widetrackman
Looking for a good used Woodmizer Head cover for a Lt 35 or something that will fit. If someone has one give me a PM or a possible source for something that would work. I don't want to just use a tarp as wind is a problem where the Mill is located. Thanks
WV Sawmiller
   I think the heavy nylon cover I bought with my mill is actually the same as used on an LT40 so you might want to be open to that too.
SawyerTed
Motorcycle covers work great.
terrifictimbersllc
I have had very good luck with Woodmizer covers.
The cover for my 2001 LT 40 Super lasted the entire time I owned it, over 18 years. I kept that mill outside and the cover was always on it. I stitched it up one time at a seam with 30 pound monofilament.
My LT 70 super cover is just as good quality, it has been on my sawmill since I purchased it new about 2 1/2 years ago.
Both are covers that cover the entire head. They are not travel covers.
With practice, they are not that hard to put on. But it takes a bit of a strategy and you do have to step up on the sawmill to do it.
Iwawoodwork
I have a pickup 11ft camper cover that is made from a breathable material that I think would work, I didn't think about it until Ted mentioned the motorcycle cover, have one of those also.  thanks Ted,
widetrackman
widetrackman
The reason I did not want a WM is $350 and my Mill is located under a 14 ft. high metal building and will not be mobile but needs a little more protection, as the sun hits it and rain blows in occasionally. I need to inclose the eves but that's another story.
