treefarmer and timberjack rim bolt pattern compatibility?
Started by RR construction, January 02, 2022, 07:38:35 PM
RR construction
Hello does anyone know if the treefarmer 12bolt rim is the same as a 1995 timberjack 230a 12bolt rim, they both measure out close to the same but couldnt get exact measurements due to rim still being on one machine, any help much is appreciated thanks
:new_year:
Southside
White Oak Meadows
Logger68
If its the same as a c5c i used a timber jack rim for my spare tire. Only difference was the timberjack rim had a deeper offset
Ed_K
 Yes they will bolt up. I have a T F on the left side of my taylor skidder and a T J on the other side. Both axels are rockwell someting 64s I think, their the heavy duty ones.
Ed K
