Stationary CSM Build
Started by subarctic_moose, January 24, 2022, 06:31:23 PM
fluidpowerpro
I own 2 Hudsons. The smaller 18" uses 2 x 2 x 1/4 angle for the track and bunks. My larger 36" uses 3 x 3 x 1/4 angle. When you set the angles in for the bunks and weld them in, the bottom of the log ends up 1/4" higher that the track, (not that it matters in your case). In either case, I have not ever had issues with the bunks bending. It is however important to support the track continuously as shown in the picture.
Change is hard....
Local wind direction is determined by how I park my mill.
