siding question
Started by colb56, May 26, 2022, 05:03:27 PM
colb56
Siding question.... I am building a chicken coop and have some rough cut  hemlock 1" thick and poplar 1" thick I milled around 3 years ago.  I don't have enough of either to finish but do if I use both.
Would it look ok to side it with both ?
Nebraska
I don't think the chickens would mind.. :D
Couldn't help myself. Will you paint it /finish it some how?
colb56
Nebraska, I opened myself up to that one.  That's something like I would say.
Yes I am going to use a exterior stain on it which is the same as my other coop and small barn to keep everything the same.  It's a dark brown and my initial though was there shouldn't that much of a difference even if the grain of the poplar is a little tighter then the hemlock.
I have 2 coops one I'm working on a 12X12 and my smaller one a 10X8.
Tom King
A long time ago, and old man told me he'd built a chicken coop out of green Sweetgum.  He said, "In about a year, the inside was on the outside".
Southside
I did a board and batten front on a chicken coop with whatever I had, species and size, gum, oak, pine, 3",4" etc.  Had to get it buttoned up and figured I would deal with it another day.  It actually came out just fine and it's still on there to this day.
White Oak Meadows
Nebraska
What Southside said. He's a chicken rancher. Even has cool egg cartons...If you take care of the exposed wood it will give you good enough service. Then the next chicken coop can extra deluxe.
kantuckid
When up and away from the ground where rain doesn't splash they both last. Down in the weather they last for a few years. Myu old chicken house, the fixed type lasted until the termites ate it from the ground up. My next a most recent one was on sled runners to move thru the pasture. I like that style and so do the chickens.
Southside
Being a chicken rancher isn't as easy as it sounds. Anybody can bulldog a 300 lb steer and pin his ears flat to the ground. Try pinning the ears on a 7 lb Barred Rock and let me know how it works out for you.  :D
White Oak Meadows
