Log ID with solid black streak
Started by blackhawk, May 31, 2022, 04:15:57 PM
blackhawk
I recently milled this log from a wooded site near Claytor Lake in Virginia.  It was already in the log pile so I don't have any leaves to reference.  The solid black streak really has me puzzled.  The black that you see covering the bottom portion of the slab in the 1st picture is just dirt where the slab had been drugged along the ground.  I've seen black streaks in poplar in my area, but it is always accompanied by yellow and green streaks.  Any idea on the species?
Lucas 7-23 with slabber. Nyle L53 kiln. Shopbot CNC 48x96
btulloh
Any coal near the surface there?
Interesting find.
HM126
LeeB
I want to say persimmon but the bark doesn't look right.
Don P
I believe you have a funky black gum there.
blackhawk
Quote from: btulloh on May 31, 2022, 04:27:46 PM
Interesting find.
No coal that I know of.  I cut several cherry logs from the same site and they all looked completely normal.
low_48
Just saw a picture identical to yours. It was in Woodwork magazine and the the photo was from Drew Langsner's shop in North Carolina. Identified as poplar and was being carved for bread bowls.
stavebuyer
Favors Red Maple with mineral stain.
Old Greenhorn
Looks like a Red to me also. That black streak appears to be early stages of fungal growth. In a few more growing years that tree would likely be hollow.
