Learning to Adapt
Started by Rhodemont, January 25, 2023, 05:09:17 PM
Rhodemont
I have the tendency to think too far ahead and become disappointed when things do not work out to plan.  The weather has certainly not been cooperating with my  retirement plan of logging in the winter, saw in the spring and fall, and do other stuff in the summer.  After much frustration with the weather this year the new plan is: drop trees on rainy wet days, use the arch to move a couple logs to the sawmill early in mornings on days when ground is a bit frozen, saw in the afternoon when the ground is thawing out.  The Ash 4x4 are moving as fast as I can saw them, the balance firewood is in a back log.  Oak sawmill logs is on hold for now pending mud.  Overall things are going well.  Delivered 40 4x4 this afternoon which alone keeps me in the green for having fun.
Woodmizer LT35HD, EG 100 Edger, JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P, MSA 300 C-O
tacks Y
Sounds like you got it figured out.
What are the 4x4s used for? 8' ?
Wlmedley
I'm with you.A little frozen ground would be nice.My log deck is empty.Got logs on the ground but waiting for a freeze to move them.
Bill Medley WM 126-14hp , Husky372xp ,MF1020 ,Homemade log arch,GMC2500,Oregon log splitter,Honda Pioneer 700,Kabota 1700 Husky 550
Crossroads
I need to thin my 20 acres and got set up to sell the white fir (I have no market for WF lumber) to a local mill in October. Well, October and November were busy with mobile milling jobs, December dumped snow and January so far has been busy with custom orders. To this point I haven't skidded a single log. Maybe I'll get a couple loads out in February or March 🤷‍♂️
Rhodemont
Tacks: 4x4 are being cut to lengths and resawn for components of benches.
Ron Wenrich
I used to saw 8/4 ash for butcher block counter tops and bench tops.  They kiln dried and resawed to match their quality guidelines.  The upper grades gave them the best yield for the dollar.
