Straightening warped green treated 6x6 posts & knife plate
Started by Sedgehammer, January 28, 2023, 10:47:46 AM
0 Members and 4 Guests are viewing this topic.
Sedgehammer
Have footings in for the lean-to posts. Have posts. I have kept them bound together to help reduce warping, but you know green treated. I plan on putting the warped sides to each other and wedge between them to straighten. 1 is as far as an 1" out in 16'. These will be 14' 6" when done
Is 1" too far to move? I will fasten a 2x12 with screws once in place to hold it plus leave wedge in place for a while
On the knife plate. I have 5"x14"×3/8" plates. I was planning on keeping the posts 2" of of the footing. The footing is above grade and will be covered with a few inches of milling once final grade is done. The outside will still be @ current grade
Do i need to keep the posts off of the ground? These are CCA treated posts. I know it's better if they are off the ground, but is it worth the trouble of making a 'bench' plate for them to sit on. Pics attached
Here's a pic of the footing. The strap on edge was for the setting of the weld plate. That will be removed
Had 3 straps on, hadn't put before this pic. Some of these posts were warped already, but some we're still wet to the touch. I know these straps stretch, but don't have a metal strap binder any longer
Necessity is the engine of drive
Are you intending the 3 straps to keep the 6x6 posts from warping while the exposed surfaces dry?
Sedgehammer
@beenthere
They are just on till I start cutting them to fit and the knife plate
@Jeff
Some are spot on, some offset, some there isn't one
The worst one is centered. I had to special order them, so no chance to choose.  The worst ones are center nearly spot on
I've found that with any treated material, buy like 30% extra and stack/sticker for air drying. Sort and return the bad actors and hope the remaining will behave in-place.
Not possible to "bend/force" a 6x6 back straight again.
Sedgehammer
@beenthere
Special order, caint return. I bought 1 extra. I know I can straighten it, just wondering on any idea to do it better
Will be interested in knowing how you can straighten it and keep it straight.   popcorn_smiley
moodnacreek
Sawing squares and drying them without twist is a losing battle for me. I do have some luck with very soft w. pine or w. cedar. Anyhow the project may not need untwisted posts especially if nothing is attached to them. In that case you plane like with a hand or power hand held plane flats on the post ends top and bottom to make the post fit as if it was flat.
Sedgehammer
Didn't say I could keep it straight  ........ 🤣🤣
But i think I can with wedges and 2x12 gerts
Sedgehammer
@moodnacreek
I've successfully twisted or untwisted 6x6x8 on my porch. Was twisted a full half turn. I made a 4 bolt bracket that bolted around it with a 10' handle. I twisted it into place and bolted it with 4, 1/2"x8" bolts thru the post and header. Can barely tell it was twisted. Wouldn't if I didn't tell you most likely
Seeing that done would make a good great video.  :snowball:
;D ;D
Don P
moodnacreek
I suppose putting them in a pond for awhile  before clamping them would help.
Sedgehammer
Quote from: moodnacreek on January 29, 2023, 09:08:25 AM
Yeah, that'd help, but then they'd be 4x heavier ...... 😱
I'll put the 4 best posts on each end. Secure them to each other with rough cut 2x12s in the middle and with an angled brace to a stake in the ground. Then I'll put the 2 worst bends towards each other on the remaining posts. I can either pound a wedge in between them or jack them apart and then put the wedge in. I'll screw a board over the offending areas, so I don't damage it. Once one is plumbish, I'll secure it with the rc 2x12s & 5 ,1/4" x 6" screws. Same as I did with the first 4
I'll not be moving much
GAB
He did mention that they were: "These are CCA treated posts."
Not being familiar with CCA treatment will that pollute the pond water?
GAB
chet
CCA treated materials are permitted for marine use. I think it's most common uses are for pilings, bridge timbers, and docks. They actually have marine grade treated stuff, treated up to 2.5 for submerged salt water use.
Don P
Dat's what we were using when da mos unfortunate dockside motorized electrocution event occurred. That stuff is bad to the bone. It wouldn't hurt to rinse it to remove surface stuff. The chemical is supposed to be bound within the wood.
I found the air drill I bought to do the wet drilling with on the in laws seawall. I had brought it home and forgot about it. I found it a month or few ago and plugged it in, after salt water, tossed on a shelf for 30 years, it worked. Cool.
GAB
Quote from: chet on February 02, 2023, 07:15:15 PM
Thanks,
GAB
Brad_bb
Once twisted, you're not moving them back.  If you really need it square, then you have to order oversize, let dry enough to stabilize, and then joint and plane to size and square.
hacknchop
I don't know what I don't know, but I do know what I know and what I  can and can't do with a timber. Now as for what somebody else can or can't do, not my call. Hope it works out good for you  Sedgehammer.Let us know.
Often wrong never indoubt
Sedgehammer
@Brad_bb I've done before, so am hopeful it moves ok
@Hacknchop Thanks
Brad_bb
I've re-read this post (read while on the road yesterday), and now I'm not sure what it's referring to - a 6x6 treated post that is twisted by an inch, or just bowed along it's length by an inch?
Constraining the two ends and pulling the bow out and letting it dry more like that will likely take some of the bow out, but I would think trying to untwist a timber would end up splitting it?
Sedgehammer
@Brad_bb sorry if confusing. I have treated 6x6s that need the bow taken out of them.  Length when up will be 14' 6". I'm pretty sure they'll come out. Just was askin for any ideas outside of what my plans were
As to the twisted comment. I have taken it out of an 7' one on my porch. Was over an 1" off straight. I moved it lil'bit by lil'bit
