Electric chainsaw for mill work
Started by dustyhat, January 17, 2023, 12:08:53 PM
Joe Hillmann
Quote from: 21incher on February 28, 2023, 07:16:12 PM
What I read is the small pack heaters take very little power and once at temp in a couple seconds the batteries create heat so it's just to get full output fast with out cell damage. I am looking at the 100ah 48 volt batteries (6x) from Signature Solar to set up a system to play with
I think it depends on how cold the batteries are when the heater kicks on that determines how much power it takes to heat the batteries.
If it is -20F and you were using the batteries heavy it won't take much to get them above freezing to take a charge.
On the other hand if it is -20f and the batteries ran out of charge and have been sitting idle for the last 6 hours it is going to take a lot of energy to get that battery up to above freezing so it can take a charge.
I originally planned to go with LIFEPO4 batteries on our house but the inability to charge below freezing and the complexity of a BMS has made me decide to go with lead acid for now and hopefully in 5 to 7 years when they need to be replaced I will have better options than I do now.
OlJarhead
For me it was 8 year old FLAs that made me look and I found more power (usable) in LiPos for about twice the price.  Considering they should last more than twice as long I'm saving $$$ 😉
Now, I do have a room I built to keep them warn so no issues there either.
I'll let you know how they work out though!
Broncman
I did my daughter's RV last fall with a Renogy 48v Lifpo system and invertor.
I placed the Lifpo batteries in an insulated compartment.  Never had an issue. We need more solar cells but her RV roof is full.
We did have issues with a Lead Acid battery freezing in another system.
I love the ability to be off grid...but it is expensive still and would love to see prices come down.
Frontier OS31 bandsaw mill
Dehumidifier Kiln with sanitize heat,
Honda Pioneer 1000-5
Stihl and Huskies...
OlJarhead
I built my system in stages over several years but it is speedy either way ;)
