Finish for wood drink coasters
Started by Downstream, July 17, 2017, 10:55:45 AM
Downstream
I have made a jig to slice limb cookies to make wood drink coasters on my band saw so now I have to decide what type of finish to apply, if any.  Seems to be a number of things people have tried but curious to what anyone on this board as had good or bad luck with.  Looking for simple if possible in case I need to do many at a time.
Split Second Kinetic logsplitter,  Stihl 211 Logrite 60" cant hook.  Used to have EZ Boardwalk Jr, Grandberg Mill, Stihl 660
tule peak timber
We use epoxy on similar projects with great success. It is  more of an "in " the wood finish than an "on " the wood finish.2-K poly may be added on top of the epoxy , but probably is not needed. Attached is a pic of some cookies in the shop right now using this "in" the wood method. End grain doesn't like water and this is where the epoxy soaking really shines. A simpler option is to heat beeswax and mineral oil and apply to a warmed cookie so it soaks in.  Cheers  Rob
Crusarius
I always love your work. that is beautiful.
bucknwfl
I made some coasters to go with the cypress table. Cut them out of a 4x4 sanded burned an L in them (Angie has to have initials on everything) then just coated with helmsman spar urethane
Buck
If it was easy everybody would be doing it
Kbeitz
Rubber tool handle coating for the bottom keep them form sliding around.
Love machine shop work
and Wood work shop work
And now a saw mill work
racslette
Quote from: bucknwfl on July 17, 2017, 01:57:12 PM
Buck
It sounds like you have created a set of unique and personalized coasters to match your cypress table! The use of a 4x4 wood piece and the burning of an L on each coaster gives them a rustic and individualized touch. Coating the coasters with helmsman spar urethane will help protect them from moisture and give them a durable finish.
Overall, it sounds like you have put a lot of thought and effort into creating these coasters. They will not only be functional but also a great conversation piece when guests come over. Well done!
doc henderson
i also use minwax spar urethan for flat sawn.  grain end it could work.  depends if these will be used for a long time.
I have done end grain ones, but they are rustic, and left raw.  not really used much.
Ljohnsaw
I sliced up a bunch of incense cedar limbs. Actually, very dense wood compared to the saw logs. I used epoxy with two coats as it soaked in quite a bit. One side came out pretty good and I stuck thin cork discs to the bad side 😉
I'd post a picture but I'm a bit far from my computer right now.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
