Caterpillar 525 Skidder Hydraulic Issues
Started by williamson210, August 28, 2023, 06:07:36 PM
williamson210
We have a 1999 Caterpillar 525 Skidder that is having some crazy hydraulic issues. When you start the rig, the Hydraulics will build pressure to 3000 psi then release to nothing. Then repeats about every 5 seconds. We have changed the hydro pump, and main hydraulic valve block. Everything works it just surges real bad when this happens. There is a small 3/8 pressure line coming off the valve block to the hydro pump, if you block that line off the surging stops, however nothing works then. Has anyone had this issue? Thank you...
chep
newoodguy78
chep
barbender
Is the small line your load sensing line?
williamson210
Yes the small line is the load sensing line
kiko
Your brake accumulators are damaged or discharged or there are issues with the accumulator charge valve.  Is this a 1DN machine or  3KZ?
williamson210
Thank you!! That would cause it to build and release build and release every few seconds?
kiko
Yes , when the nitrogen is discharge there is no cushion and it will slam when it re charges.  If the accumulator was holding pressure it would not cycle that much.  The function of the brake accumulator I to allow to still have service brake function in the event of an engine stall.
