Husqvarna 154SG bar length
Started by DHansen, January 26, 2025, 01:36:07 PM
DHansen
Picked up two more inexpensive replacement bars for the 550XP and the 154's.  Hardwear store that wants to get rid of old stock that is not STIHL.  Been a good spot for me to pick up discounted Husqvarna, Jonsered and John Deere stuff. I also ordered a Husqvarna solid bar with replaceable sprocket tip from the saw shop.  Same size and spec as these.
DHansen
Husqvarna sure has a lot of marketing names on their chainsaw bars.  Farm Tough, Rancher, X-Force, X-Tough, X-Tough Light, X-Tough Solid and X-Tough Professional.  And there are differences in the bars.  I wonder if it is done to fit into the customers price ranges or actual performance and customer needs.  Maybe a blend of both.
DHansen
I richened up the 154SE to lower max RPM by 1000 RPM.
The NOS Total Super bar on the 154SE.
DHansen
DHansen
Quote from: Spike60 on February 23, 2025, 06:58:13 AMAnxious to see how this turns out.  ffsmiley
After leaning out the 154SG and richening up the 154SE.  Removing the 3/8" - 20" bars and going to the .325 - 16 and 18" The 154's are cutting very nice and an improvement from what they were like.
The 550XP is lighter in weight, but all three feel good, balance well and cut great.  I cannot say one is superior over the other. There is a sound difference and weight difference, but they all get the job done.  The 550XP is auto tune and stock.  If wanted I can lean out the 154 and pick up another 1,000 RPM.
Spike60
This is a great thread. Wish you were in driving distance. Post #51 broke me up. Stringing all those marketing terms together shows that someone in marketing should have applied the brakes at some point.
Throwing in the new 550 to compare with the 154's is a good way to show how far we have or haven't come over the years. However, the conclusions from these models is unique to them and wouldn't necessarily apply to other saws. For instance, IMO the 242xp is one saw that has truly never been replaced. The current 543xp is nice, but doesn't come close. The icon 372 is a tough act to follow. The 572 seems to have succeeded where the 575 and 576 fell short. 288 vs 385/390? I'll go with the 288. So sometimes the new model raises the bar, other times the outgoing saw remains the preferred model.
Much of this is objective and personal preference that goes beyond what can be measured with cookie times, compression numbers and scale weights. When concentrating on the job at hand some saws just feel better to work with than others. There's no right or wrong, it's like adjusting the seat in your pick up to where you like it. And you've done that here with the 54's by changing the bar and chain setups to make the saws more enjoyable to work with.
The best thing though is shining the spotlight on this chassis and sharing the info with everyone else. Keeping the older models in focus is the only way to broaden our saw options now that we are down to essentially 3 manufacturers. Granted, the old saw option is mostly limited to guys who are handy and can work on the things. And parts availability will always be a changing dynamic. But if we were limited to only what was new at the local Husky, Stihl, or Echo dealer this wouldn't be any fun at all. (And Shindaiwa; the Japanese Jonsered)  ffsmiley
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
DHansen
Don, I took two more of the mufflers off and looked at taking the two halves apart.  Both of these have a rolled edge were the bolt passes through that holds the two halve together.  If I wanted to attempt separating the two halve I would need to dremel off the rolled edge or drill the top area off with an oversized drill bit.  I think this rolled area hold the two sleeve in place inside the muffler.  The bolts pass through these sleeves.  With the RPM I am getting I question the need for any muffler modifications.  That is so far.  We will see.
donbj
You were more observant than I was noticing that. There is just about as much metal inside the muffler as the outside from what I saw in mine, though I did manage to snake some out.
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
DHansen
Must be several slightly different designs of these mufflers.  This next 154SE muffler came apart with a little wiggle and pull.  The rolled edge on this one was only on one halve of the muffler, keeping the sleeves attached to that halve. The sleeves stay attached to one side of the muffler shell on this one.  I think I will modify this one and use it on the 254SE and also do some work on the air filter to carburetor elbow and see what happens.
