390xp, 395xp, or 592xp for 36" Granberg Alaskan mill?
Started by semihandyAndy, March 05, 2025, 10:36:35 PM
semihandyAndy
Hello guys,
Need some advice on which saw I should get for a 36" Alaskan chainsaw mill (maaaybe a 48" someday???). I will be casual user, for woodworking & barn repair timbers off my woodlot after I retire not long from now.
I run 3 smaller and older Jonsored saws, and do not have a lot of experience when it comes to saw carburetor maintenance / repairs.  My 3 saws have spoiled me!
So which of these would be be OK for what I am proposing? BTW I just came across a chance to buy a 390 in like new condition (<10 hours run time) for $950.
Thank you & hope to hear back from some of you,
Andy
ehp
395 all day long and everyday , Very good saw for a mill
Or the alternative:  Get a cheap bare bones bandsaw mill. A $2200-3500 mill will make lumber and square posts and run circles around a chainsaw mill.  And you'll enjoy it more. :thumbsup: If you were at a remote location with difficulty getting into it, that is another matter. But out on the homestead, get a bandsaw mill.
arojay
As far as the Granberg goes, I run a 394xp.  A friend uses a 3120xp.  The results are about the same but he burns a lot more gas.  If I was thinking of a larger/longer mill I would likely go for the bigger saw though.  Swampdonkey brings up a good point if you are setting up in one location.  My son had a Woodland band mill when he was building barns and sheds and they are a lot faster.  Depends on your circumstances.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
semihandyAndy
Thank you all for the excellent advice!
Yes, I agree that a mill is the way to go, but some of the trees that come down due to storms are falling in wetlands where removing slabs individually is much more feasible than a whole fat green hardwood log.
I have to buy a big saw anyway, and the Alaskan is just a short term solution.  I'm pretty sure it will be easy to sell around here once I get a mill and a better tractor to move the logs to the mill.
Of course I would also need to build a kiln, and a shed to store the mill, and buy a winch for the tractor, and so on ...
The more I think on it, the more spendy this dream becomes!
ehp
To run a 36 inch alaskan mill the 395 is the only choice of those saws , it has a carb you can set richer to deal with the engine heat and has the power
semihandyAndy
ehp
If you want or can  I would have you or someone do a muffler mod on the 395 to help get cylinder heat out of the motor , Putting a chainsaw on a mill is quite hard on them so anything you can do helps the motor last, When you get the 395 break it in abit before putting it on the mill to give the motor a fighting chance , When you are going to put it on the mill MAKE SURE YOU RICHEN the high speed jet up , Fuel cools the motor so say at the start of your cut you got the saw set at 12,000 rpms out of the wood if your coil does not limit the rpms , , then you do a 3 to 5 minute full throttle cut and now check the rpms with non limited coil , the saw will scream real high rpms because its real hot . I have lots of guys milling and pretty much the most common saw is the 395 , some use the 3120 or stihl, on the 3120 we drill the brass jet out a couple sizes to give the saw more fuel
semihandyAndy
Picked up a used Made in Sweden 395XP. It's got some wear but seems to have been very well taken care of. What a saw! I have never bucked up fat oak logs so fast before.
ehp I will be sure to follow your advice on the mods for milling to help extend the life of this fine saw, though I will need to find a local expert to help with those.
ehp
The 395 is a very good saw, touch heavy for most guys but well built .
