Nails and other fun things to find...
Started by WkndCutter, January 26, 2006, 12:42:45 PM
WkndCutter
I have lately found a few logs with nails in them.  I cut mostly small jobs.  I guess I've been lucky.  Bottom line, what is a good metal detector to use to scan the log prior to cutting?  The good news is I haven't ruined any blades yet.  Last year I found a fence post with a chain saw.  A good metal detector migh come in handy.
Andy
Troy
I have heard that a "new blade" is the best metal detector around!  Other than that any of the mid to upper range metal detectors will work fine.  One with a sensitivity control preferably.  I think mine is a bounty hunter, just under $200.
Peterson ATS 8" 27hp
leweee
Part_Timer
The ceramic insulators are the best  ::) ::)
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
Brad_S.
I came to the conclusion that for the amount of time I was spending scanning logs, many times it was cheaper and easier to just cross my fingers and go for it.
jpgreen
A Fisher "Gold Bug".
The original model can be picked up on Ebay for under $300 used. You need one that the sensitivity can be cranked up on without any filters.
The great thing about this machine is it's a full non discrimination detector that will pick up a nail at 12" deep if not more, allowing you to scan a log fast.
I've used one for years.
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
rebocardo
I thought 80 pounds of concrete was best.
WkndCutter
Thanks for all the help.  I'll be looking into a metal detector. Maybe ebay.
Andy
