Clutch slipping fix//
Started by JP, February 11, 2006, 05:18:35 PM
JP
Hi All:
One of the majer problems with the B$S 23 hp on the Norwood LM2000 was clutch slipping// The cause of this was the 23 hp motor not reaching the 3600 rpm required to ingage the clutch fully --Robert from W MI provided a simple fix for this by first moving the gov. spring over to the rt hand slot  as shown and then putting a # 6d nail ground on 2 sides and cut off about 3/4 " long in behind the spring. this upped the no load rpm to about 3900 and the load rpm (om mine) to about 3610/// no slipping noted in a 18" cut at 22 fpm cut.   JP
Norwood lm2000,Newholland 30 hp tractor, log carrier/winch, log arch  JP
Percy
DanG, I been told my clutch is slippin and my name aint even Norwood :D :D :D
sawguy21
Percy, that sounds like a non mill related problem. :D
