pulling out a windblow
Started by Dan_Shade, April 10, 2006, 09:26:28 PM
Dan_Shade
lots of dull bands and chains
Looks successful to me. Nice going.
What were you winching it in with?
Or pulling with the tractor?
Dan_Shade
the milemarker on my truck.  a tractor would be nice too, provided you have a screen or whatever to avoid a headach if the cable breaks...
i drug out several pines that way, it was doing pretty well, but I should probably brace up the arch if I do it too much.
Kevin
Reddog
Looks pretty good. But I agree with you if you are going to do alot, it may bend your arch. I have seen similar tripods that farmers have used to pull stumps and every once and a while you would see a pretzle also. :D
maple flats
rebocardo
Looks good, what does the arch do, keep the butt end from digging into the ground once you start winching?
Dan_Shade
yes, it lifts up the butt and lets you drag it out nice and easy.
Deadwood
Nice video.
Just for your information, if you are worried about a cable snapping and recoiling back and hitting you, place a jacket over the winch cable. If the cable does snap, the jacket will keep the cable from recoiling back. Obviously you want to keep the jacket somewhere in the middle of the winch line.
Again, not trying to be a know it all, just thought I would pass along this piece of safety advice until you can get a protective measure up on your truck/ tractor.
