Fire Pits
Started by Radar67, September 29, 2006, 07:40:39 PM
Dang, yah gotta unnerstan this here's for cook'n fancy, smoked, thick steaks. Gotta go all out, no skimp'n. Dang is yer belt loop any indication of yer cook'n. ;D :D :D
Ain't nuthin skimpy going on around here.  I got me a genuine 55 gallon drum to do the cookin' on.  That ol' Dodge wheel is just to keep me feets warm in the wintertime.  I have been known to cook a pot of collards or boil some peanuts on it, though.
Murf
Quote from: DanG on October 05, 2006, 09:17:10 PM
Good job ya don't live up here then, by the time ya got da fire big enuf der wouldn't be enough wood left ta saw none...... :D
Mooseherder
Here is a new addition to the Southern Fire Pit without my machinist buddy. ;D
19 dollars worth of pipe /fittings and a 6 quart cast iron cooking pot picked up at Harbor Freight for 17.00
Its 1 inch(4 ft. length) pipe with coupler, then a 8 inch long attached to the coupler.
Then slid a 1 1/4 threaded T over the Top Pipe. It rests on the Coupler and allows for the Swing pot off fire if desired. A 1 1/4 pipe(12 inch) with a 45 elbow completes the Kettle holder. A 1 inch cap allows you to pound the pipe into the ground. :D
My sledge is in Maine, so I had to pound the pipe in with my Truck Ball hitch mount. :(
That is RN Cabbage in the bottom left. ;D
Mooseherder
Here are the ingredients that went into the Pot.
It Started out as a Clam Chowder and ended up a cross between Gumbo and Chowder.
mmmmmmmmm...mmmmmm
