stihl 028 wb
Started by mountaineer, March 03, 2008, 08:30:04 PM
leweee
if the chain stops traveling at that idle speed,and it preforms well in the wood you should be good to go. ;D
mountaineer
to be honest leweee, i still think it bogs more easily than my wb does. would i need to get the rpms a little higher?
leweee
Quote from: joe_indi on March 07, 2008, 08:44:53 AM
Quoteit also bogs when i give it full throttle.
This is a frequent problem on some Stihl saws (028, 038, MS380, MS381)that have the choke shutter in the air filter instead of in the carb.
This type of choke is held back by a spring.If the spring is weak or loose, when the engine is revved up, the higher air flow causes the shutter to go into the 'close' position.
In the worst cases it remains closed until the engine dies from flooding.
Usually it closes at full revs, opens as soon as the revs come down, and keeps doing this as long as you have the throttle fully pressed.
If you didn't know, the symptoms would make you suspect the ignition system.
The cure is simple.Either tighten the spring a bit or use the spring from your old filter, since it seems to work fine.
Joe
[/quote
when reving the saw ,watch the choke  flap to see any movement...
did you clean & rebuild the carb?....check fuel filter & line....impulse line from crankcase to carb. ???
mountaineer
it runs good,  just not what i thought it would be with the extra cc's. i don't think it's much more than some tweaking of the high jet.
leweee
when they were both new you would notice a bigger difference. ::)
now that they are pensioners 4 or 5cc's isn't a biggy. :D
