thin cuts
Started by robdunn, August 22, 2008, 10:30:02 PM
robdunn
new here.
what is the thinest, repeatable cut you can continually get, and on what type of mill?
lot's of wisdom on this site.  Thanks
peterduncan
We can get 1/16" in the Timberking B20
robdunn
thanks again.
my actual interest is in guitar wood, which i am unable to resaw wide enough pieces on regular shop tools.  that got me interested in bandmills, and now i think, after seeing some of the amazing(rare I presume)wood all you guys are cutting, i am more interested in sawing than the instruments.
pineywoods
I cut a lot of 3/16 oak and ash for fish trap throats and can easily go thinner. Just for grins and giggles, I have cut some pine so thin it's nearly transparent. That's on a woodmizer LT40, up to 22 inches wide...
sawmilllawyer
Welcome Robdun, there are a couple members who are instrument makers, maybe they will chime in with some hard earned knowledge.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
shinnlinger
Welcome,
I'm w/ Piney, I have sawn "post cards" and "paper" for friends, family and my daughters class on my mill.
I bet any bandmill could do it, but some might have a better height adjustments if it just had to be exact every time, without a lot of fiddling.....that said, I bet you could run the thin stuff through a planer or surface sander with a backerboard for really precise work and in fact I might try this in the near future.
Maybe my wife will get a new lampshade out of the deal!
Shinnlinger
robdunn,welcome to the forum.Here's something to read until others come on.
https://forestryforum.com/board/index.php/topic,2187.0.html
Go to the top of the page and click on to search and put in thin boards.There are more threads than the one I listed.Put in others words and you will find more threads to help you out.
Be careful,the sawdust addiction will get you.  ;D
Dave Shepard
I've sawn as thin as .030", with minimal deviation over the length and width of the "board". With a kerf of about .100", you are making three times as much sawdust as "boards". :D
Dave
Lud
I saw thin and then put it in the steamer.  Still exploring the process but suggest/propose that one should saw with the grain  or split initially and then saw to have the same fibres in the thin board as possible. ;)
solidwoods
I think I'd saw it then sand it to thickness with a drum sander.
That will ensure exact thickness, uniform thickness and sand the surface.  If you are bending thin wood any deviations in thickness could make spring back unpredictable.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
ohsoloco
robdunn, from the sounds of it you're looking to resaw wood that's already dry  ???  Just about any bandmill can cut paper thin slices off of a fresh log, but dry wood is entirely different.  My Norwood can also saw wood so thin it's translucent, but someone I cut some 2" thick walnut for years ago brought some back to split in half  ::)  After a few inches into the cut the blade dove.....I got it split, but I know I couldn't make consistent veneers with dry wood on my mill (with the blades that I have, anyway).
Perhaps with a different blade I could do it, but most mills can only cut down to about 1" or so from the bunks, unless it's fastened to some kind of riser or jig.
