Blue stain
Started by bandmiller2, August 27, 2008, 06:07:21 AM
What do you fellers do about blue stain in white pine??We pretty much don't cut it when the weather is hot and humid,of course thats no good if you make your living with the mill.We have had some luck sticking it good and blowing air from a fan to dry it quicker.
solidwoods
Dip or Spray it with a lumber fungicide.
1.5" tall dry sticks, 3' long, 2" between boards, bottom layer well away from the ground (no grass).
Or straight into a kiln or a drying shed with fans
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
backwoods sawyer
Out here, there is a demand for blue stain in lodge style homes. Whether it be stripes or blue as a pair of blue jeans. When milling it we sort for color. After milling, it is stickered and air-dried. The color seems to stay consistent with when it was milled.
Backwoods Custom Milling Inc.
redprospector
Try a little house hold bleach mixed at about 25% with water.
But like backwoods sawyer, we have a demand for the "blue pine".
Andy
Mad Professor
Keep it too wet to stain, e.g. constant sprinklers or in a pond. Otherwise mill ASAP or in  fall-spring
Meadows Miller
Gday Frank
I get it bad on the Radiata pine we mill overhere the average temp for the year around home is 89of and for 4months during summer av is 96of and our hot days can get upto 118 of not bad weather for drying/fires I tend to mill grade orders strait away as soon as the logs  arrive or within the week case pallet and sleeper orders
the logs are sawn within the month .
On my sawn grade timber i use a chemical called dmold it dilutes 20/80 with water
but i only use that when the humidity is higher spring/autum as drying times are slower
in the middle of summer I can airdry 2 inch boards down to 10 to 12% in 2 to 3 weeks and inch boards can dry witinin a week  with sunny windy days .
great days for fires  :o but I dont want to dry my timber that well :D :D :D ;D
Reguards Chris
4TH Generation Timbergetter
amberwood
I have a similiar question for exporting cant, I have a customer in korea who wants 200*200 cant(8*8") in shorts for resawing. the problem is getting it there without massive amount of bluestain or mushrooms..they are just going to be too big to airdry in any sort of reasonable timeframe. A sealed shipping container is a great place to grow mushrooms on wet timber.
Has anyone has success with anti-mold chemicals for larger section sizes?
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
ARKANSAWYER
  Saw fast, dry most quick is the best way.  Bleach or Fungus spray works if you coat the wood well.  Dipping is how the large mills do it.   We do not worry about it for the most part and have a good market for the pretty colored wood.
ARKANSAWYER
ely
now that imo is a good lookin piece of lumber. i have yet to get that sort of blue stain. most of mine would be called light comaparitivly speaking.
ARKANSAWYER
  That was made blue.  Most of the time it will just be in spots along a board.  That was blued so we could make some paneling for a home.
ARKANSAWYER
Meadows Miller
Hi Duncan/Amberwood
I looked into exporting flitch 4x4 6x6 8x8 10x10  10' and 14' lengths to china a few years ago Have You talked wiht RADEX in Geelong They are alot cheaper than container freight plus you can get it on as deck cargo plenty of air movement if You put some sticks in between each row as itts packed. Id use DMOULD its made in Melbourne ill get the details for You. I just apply it with a 20lt/7gal backpack sprayer but if You where doing any large volume id build a diptank .
Reguards Chris
logwalker
Quote from: ARKANSAWYER on September 03, 2008, 06:14:04 PM
How did you do that Arky? Pretty stuff.   Joe
backwoods sawyer
Seems to me that all exports have to be kiln dried to kill the bugs, (may be just a west coast thing) but getting the moisture content down would also stop the blue stain.
Meadows Miller
Gday Backwoods
Export of GOS Case grade flitches has been going on overhere for the past 25 years since the Ash Wednesday Bushfires wiped out a good part of our pine plantations in VIC and SA One company even set up a special flitch mill in Portland vic exported nearly 1.2 million tons of flitchs and chip over 2 years just from the mill .
There is a BIG market in Japan, China , Korea , Taiwan what they call case grade flitch mainly 6x6 8x8 but as we all know they want to pay bugger $450 to $495 per 1000bft all for it because its ment to be going into packing cases and pallets but Who knows where it ends up
reguards Chris
