Classic 6048 stovepipe cap
Started by boyno, January 18, 2009, 09:39:20 PM
boyno
We had a CB 6048 installed 9/08.  Was running fine for a while, then seemed to burn slowly and cold. There was water on the bottom of the firebox, and the coals (very little ash) seemed to be damp.  We are burning a lot of green wood, and I was blaming it on this.  As the weather turned colder, it was harder and harder to get the *DanG thing up to temperature.  Finally, I thought a bit--the chimney cap installed was a triangular, with what looked to be a 4 inch opening.  Thinking that it didn't make much sense to reduce an 8 inch stovepipe down to 4, I knocked the cap off with a 1" X 6" (we have 3 sections of pipe).  I looked inside--the cap is a solid 4" pipe (the triangle is just for show), except now it was basically a 2" pipe because of the creosote buildup.
Result--boiler burns great, burns hot and burns down to fine ash.
My question, however, is who is the idiot who would think that this was a smart idea?  Looking at all the pictures of other boilers, I never see a cap--and the new State of Maine regs require that no cap be put on.
This couldn't have been cheap--stainless steel--but it makes me wonder how good CB is when design and efficiency are concerned.
I'll try to get some photos soon.
The trees are drawing me near.  I\'ve got to find out why.
logwalker
Makes me wonder why you had so much creosote. Joe
Tom Sawyer
The creosote would have been from the green wood that he was burning.  I have been burning a lot of green pine slabs and as a result get lots of creosote.
boyno
Sorry, guys--I forgot I threw this question out to this forum.  I'm also on the CB forum.
The creosote was from the green wood, but the rapid build-up of it was from the restricting chimney cap.  Since taking it off, the fire is burning hotter with hardly any creosote (or at least it gets burned up in the stack.  I guess what I'm looking for is anyone else who had a chimney cap as a standard installation on one of these boilers.  I think that it was a waste of money (the cap, not the boiler)
