file size
Started by missourilogger, February 08, 2009, 03:50:02 PM
missourilogger
I'm just starting to file my chains and was wandering what files to use. The chains are 3/8 pitch 0.63 gauge. Can anyone help me
i Was here
and here
dsgsr
I'm running 3/8 and use a 7/32" file. I'm assuming you are talking about round ground tooth.
David
Northlander band mill
Kubota M59 TLB
Takeuchi TB175 Excavator
'08 Ford 550 dump
'87 International Dump
2015 Miller 325 Trailblazer Welder/Gen
missourilogger
I'm pretty sure that i run square chisel. I really dont no. All i no is that my chain is the yellow stihl chain 3/8 pitch 0.63 gauge 66 drive links.
i Was here
and here
Maineloggerkid
When I'm forced to buy stihl chain on my 372xp, I use a 7/32 file.
JD 540D cable skidder, and 2 huskies- just right.
Loggers- Saving the world from the wrath of trees!
outdoortype
Good job on the link Kevin.  Stihl specifies 13/64" for 3/8 but the guys at the local Stihl shop told me you could use 7/32" without any problems.
M.Logger,have a good look at one of your chains square ground will have a right angle in the corner of the cutter.You probibly have round ground chisel,if not you can still use a round file and convert it to round ground.Its quite tricky to square file a chain right, best left to a grinder.Frank C.
Rocky_J
Let's not confuse him with the square ground talk, since that style of sharpening is usually limited to pro loggers in the PNW.
Stihl recommends a 13/64" file, although I disagree. Every other brand of 3/8" chain calls for a 7/32" round file and I find that I get better results using a 7/32" file on the Stihl chain as well. The difference is miniscule but the 13/64" file can be too small leading to a 'duck's beak' on the cutting tooth top surface with too much hook that isn't really sharp.
missourilogger
Quote from: Rocky_J on February 14, 2009, 05:33:07 PM
thats wat happened to me. my friend who has been cuttin for a long time i mean a really long time told me to use a 3/16. so i did then had to go back with a 7/32 and make the chain look about like it was sharpened 4-7 times. but now its cuts like butter 8) 8. thanks ;D
i Was here
and here
