Pine log cabin
Started by pineywoods, August 27, 2006, 03:50:00 PM
shtickhead
Nice cabin, did you spike or pin the logs together?
Is there a way to notch the ends without turning the logs end for end on the mill?
pineywoods
Quote from: shtickhead on February 22, 2009, 01:18:36 AM
Spikes through the tails and the window and door frames.
Not that I could figure out. Putting the bandblade on backwards don't work ;D
customdave
Nice cabin Pineywoods! As far as putin blade on backwards, don't fret , least you didn't forget where you last parked your mill :D
                                   Dave
Love the smell of sawdust
Tim L
Do the best you can and don't look back
pineywoods
CustomDave, I ain't too sure about that, I think I left it in the saw shed, but I might better go check,  I have put the blade on inside out, teeth pointed the wrong way.. didn't cut worth a DanG..
jerry-m
Looking good piney... Sorry I missed this thread at the begining...
Jerry
