grapple skidder
Started by Maineloggerkid, October 20, 2008, 05:37:17 PM
Maineloggerkid
that could be a problem. How much is the asking price, and what condition is the machine in?
Also, how much would it roughly cost to truck a skidder 1800 miles? A buddy just got a skidder from Pennsylvannia and it cost $3200. :o
JD 540D cable skidder, and 2 huskies- just right.
Loggers- Saving the world from the wrath of trees!
KyMasterLogger
price is 16K. its in fairly good condition, it has a few hyd leaks here and there. the center pins show some wear. will need a new seat in the near furture. cold oil pressure at 70psi, warm at 40psi. hours are unknown. it just finished a job with 580K bf of hardwood and 400 tons of weighwood. it pulled a little over 30K bf last week. 40% tires
a very, very rough estimate for trucking is 3 bucks a loaded mile. maybe a little cheaper now that fuel prices have droped.
Kodiakmac
Just a thought: US Dollar is WAY higher than our Canadian Loonie. Maine isn't very far from New Brunswick, Southern Quebec or Eastern Ontario.
Federal and Provincial Acts and Regulations are killing the Forestry Industry in Canada.  Mills are closing right, left and centre (Mostly becase of the left). You can pick up used skidders in wonderful condition for $8 - $12K Canadian...do the math.
Just go to google.ca and enter   (brand) skidder, skideur, or debsqueuse...you'll see what I mean.
Robin Hood had it just about right:  as long as a man has family, friends, deer and beer...he needs very little government!
Kioti rx7320, Wallenstein fx110 winch, Echo CS510, Stihl MS362cm, Stihl 051AV, Wallenstein wx980  Mark 8:36
Kodiakmac
Sorry, that should be ' debusqueuse ". Just a note about googling Canadian sites for skidders. Just like 'Skidoo' in Canada is used as a name for any brand of snowmobile, Cats, John Deeres and Franklins might be found under the headings of Garrett, Treefarmer  or Timberjack.
Maineloggerkid
I'll have to look into the Canadian angle, thanks for the idea.
16 thousand is alot cheaper then they are going for up here, thats not a bad price.
Kodiakmac
Yup, I picked up a used JD440 in great shape for $12,7500 Canadian.  That would be about $11,000 US bucks.  Prices seem to be real cheap in that area of Quebec north of the N.B border.  I've seen several 230 TJs and 225s that appear to be in decent shape and C4s and JDs as well.
Here are 2 sites you can checkout:
http://www.lespac.com/recherche-iz/vehicules/machineries-commerciales-agricoles/tout/1237/12/49/0/1/debusqueuse.html
http://www.publiquip.com/Forest.asp?IdC=344
Good luck...
AlexHart
For whatever its worth I bought a Franklin 132 forwarder that was in Rockford Illinois and it cost $3800 to truck it out here to Connecticut.   That was I believe a little bit over 1000 miles and it was a legal load both weight wise and width wise.   Of course any 440 will be easily legal also.
And this was in early May so fuel was a little bit worse then than it is now.
Kodiakmac
Yup, floating can be costly.  It's running at about $100.00 - $110.00 per hour up here for a highway tractor and a low-boy.  Nice thing about the small skidders like 225s, 440s and C4s is that you can legally get them on most trailers that will haul a backhoe.  So that's easier on the pocket book.  Fellow down the highway has a tandem gravel truck with a 10-ton trailer that he uses to move around his little dozer and he's happy with $65.00 CDN per hour...that's about $53.00 USD.
Maineloggerkid
Well, this guy that I can get the grapple from will move it here for $75, and it looks like I might be getting it today or tommorow.
Maineloggerkid
The grapple came today, and it runs pretty good. Everything works, no major leaks that I can see ( yet), and the heater is toasty warm. I pulled a couple drags to get a feel for it, and I think this arrangment will work fine for the time being. I have a lot of pine and thin stands of spruce/fir to cut. The only quam I have is that it is not as quick to operate these models with the 2 sticks to operate the grapple, versus single stick w/ buttons.
John Woodworth
With a good faller and directional falling, thats one of the uses of the blade on a skidder is to push up turns. Sure it's nice to just go out and pick up a ready made turn of logs but in hand falling it doesn't happen. I do the same cable or grapple start pushing butts straight back till I have my turn, some times a side push. I run 4 to 6 cholkers depending on wood and you can fill them fast, with a grapple it's easy.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
spencerhenry
a 440 jd is small enough to haul with a pickup. i haul my massey ferguson on my tandem dual gooseneck. it weighs 15,000
