Calculating board feet in a log.
Started by Dieselrider, October 31, 2009, 10:14:25 AM
Dieselrider
I am cutting some pine out of my wood lot to build a pig pen and a couple other projects. I have walked around using a Tree stick scale to estimate the total number of board feet in the trees so I know how many to cut. The tree stick is calculating the number of 16 foot logs per tree and gives some estimates as to the total bd/ ft per tree.  I have my list of lumber needed and the lengths needed but, how can I tell how many bd ft of lumber is in a certain log say at eight feet long or at twelve feet long so I can know when I have enough 12 footers and enough 8 footers cut? I am not a logger or a forester but, I have cut locusts for poles and pulpwood etc,but this is the first time I have needed to calculate just what is needed for each length. Is there a standard to use. Thanks.
Always try to be the best, but never think you are the best.
You can use the Forum tool box, use the tree volume estimate that needs the diameter at breast height and your log length estimates. :)
https://forestryforum.com/calcs/Board%20foot%20calculator.htm
Hope that helps.
Dieselrider
I hereby announce I am a dope! All I had to do was turm the tree stick scale over and there is the exact information I needed. Talk about not seeing the forest for the trees!!! Ok, now I am going to hide my head before any of the real loggers and foresters show up. smiley_whacko
LeeB
All those real loggers had to find the other side of the stick too. None of them were born knowing how to use it. ;)
Quote from: Dieselrider on October 31, 2009, 11:39:45 AM
Nope,  The only dumb question is an un-asked question...... :)
Sometimes I wish that it was as easy as looking on the other side of the stick :).
Good luck with the project!
