E2300 Solenoid/fan panel clips
Started by renegadecj, February 11, 2015, 03:58:49 PM
renegadecj
I've had the E2300 since they first came out, and the spring clips that hold the panel closed have slowly broken.  Had 2 till recently, now just lost one more, which makes it tough to keep closed.  Been using duct tape while I look for a replacement.
Anyone have an idea what these are called?  I've looked at our local hardware stores with no success, but thought if I had the proper name I could search online.
doctorb
I do not know what they are called, but I'm going to need a couple by this time next year.  I'd ask CB.  Can't be too expensive.
boilerman101
I agree with Doctor B
I would call your dealer for replacement clips.
Logging logginglogging
I bet you could use a little bolt and nut through the hole making the bolt stick outward, and have a small hole drilled in the bolt so you could pit a little pin in it to hold the doors closed. That's if you can not find a replacement. I have a bungee and hardware off of a snowmobile cowel holding my reaction door tight, that works great. It was like that when I bought it, I personally have never had any problems with these little spring latches.
Ford_man
A pic would help. I do know that menards has a very large assortment of latches.
