Band parts for Christmas
Started by sawdust, January 13, 2011, 03:53:25 PM
sawdust
Not really for Christmas but a gift anyway.
I have been given some what I can only assume are bandmill wheels and a motor. I have seen a bandsaw cutting, (customdave) but have never looked inside one.
The two big wheels are about 18.5 inches in diameter, one has a yellow plastic band around it. I don't know if the other wheel is missing the band or does not require one. The small wheel label seems to indicate that it is a brake. Bearing in one wheel but not the other.
The motor is 1725 rpm 10hp single phase says it draws 40 amps.
Everything is new and not rusty!
I started building a swing mill a couple years ago.... nuf said!
I built a walking beam 27 foot long 42" between the rails trailer for the saw. I think it will be perfect with the addition of a 1/4 inch edge for the saw to guide on.
There are a couple other pictures in the gallery.
I really liked the design of the lumbersmith and may try to recreate it. It will weigh more than their 150 lbs though.
David
comforting the afflicted and afflicting the comfortable.
terrifictimbersllc
Wow, 10HP single phase motor, congratulations  :o :o :o :o  probably worth a few bucks, going to need some fat wires on that one!!!  :o :o :o :o
sawdust
Had not given the power cord much thought. I did get some huge armored cabling when our hospital was renovated. I cannot carry it.
Do you know if that drive wheel is supposed to have a covering on it like the yellow on the idle wheel?
sawdust
I have looked close at the wheels. There are no markings... Anybody recognize them?
