440a john deere skidder
Started by phil-tinker, October 13, 2010, 04:03:24 AM
phil-tinker
     have been cutting wood for personal use at home for 30 years  me and my son bought a skidder 440a jd and want to know everything about it one problem we have right now is putting in the pto as to operate winch it grinds have to shut off put in pto and start up synchro tranny does any one have solution
snowstorm
its not a pto...ita a winch drive.....do not put in or out of gear with the motor running you will break something..........it drives off the pressure plate thats how it has live power to the winch
phil-tinker
so i have to shut machine off every time engage winch then restart machine
snowstorm
grassfed
You can leave the winch engaged all of the time. The later models did not include the shifting lever. The hole were the lever goes into the trans is plugged. I think that the winch shifter was more trouble than it was worth. I work in the cold and it is better to keep the winch Hydro oil circulating to warm it as much as possible.
Mike
Bobus2003
Yes, Leave the Winch Engaged.. Just use the Cable & Lever mounted to the seat to mannage the winch.. Seen a few things get torn up when the Lever is engaged/disengaged when the skidder is running.. Only other big problem i have ever had with my 440 is the Front axle difflock malfunctioned and if the diff lock is engaged it will pump the front axle full of hydraulic fluid till it blows axle seals... That and the fact my new engine is putting out over twice the stock HP ;D so clutches slip, and i have a few Tire and U-joint issues.. :D
phil-tinker
any other issues --where might i find fuel tank for 440a
Bobus2003
I'd give these guys a hollar.. Schaefer Enterprises of Wolf Lake, Inc. http://www.sewlparts.com/Default.aspx
snowstorm
Quote from: phil-tinker on October 15, 2010, 06:18:27 PM
fuel tank......that wont be fun .....have to break the skidder in half to replace tank i would build a tank if i needed one. if you have one built make sure they put the sump from the old tank to catch any water.
Bobus2003
Quote from: snowstorm on October 15, 2010, 08:21:34 PM
I changed mine over so that i'm actually using the water drain as the supply for my Fuel.. Makes it so i can run more of the fuel out of the tank.. had it this way for 6 years now and I hardly ever see more than a drop or 2 of water in my Fuel filter at Filter change (500 Hours)
