Advice on which hand planes to buy first?
Started by Piston, September 25, 2010, 04:58:39 AM
Dave Shepard
I played around with the plane a little today. I didn't go crazy on it, but it is cutting well. Cross grain was a little fuzzy, but my other planes were doing the same thing on this block of wood. I'll get it shipped maybe tomorrow.
Piston
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
routestep
mmhailey, for housings I can only use a plane if the mortise housing goes across the post, like a girt or tie fitting into a post. I don't use a plane on a mortise with a housing for a brace.
Generally I use an electric router on all mortises to get the depth, just a quick pass along the edge, a little deeper on the inside of the mortise. Then I take the skill saw an kerf the waste wood. Then a chisel. I could use my hand router to clean up a corner but never have on timbers.
I have a very heavy Record No. 073 shoulder plane. Bevel side is up, but it is not a low angle plane. Its 1 1/4 inches across and 8 inches long. It would clean up a housing but you might as well get the LN 10 1/4 with a snicker or a fillister (Stanley 78). These planes could only be used on housings going all the way across the post.
Bridgewright
I guess I don't get the Plane in the housing thing - Planes are used to make things flat, even if I were joining dead dry timber, I wouldn't be inclined to make a housing flat. In green timber I am with intent doing otherwise.
To the jist of the thread, I see a need for, and use only three Planes in my timberframing work. A Block, a Rebate and a Smooth.
In my case these are an early (2-18-13) 1 5/8" Stanley low angle Block, My 10 1/2 Type 1A (adjustable throat)  Rebate. And every now and again (for very large tenons) I'll pull out a Smooth Plane - Mine is a Millers Falls No. 9 (equiv Stanley 4)
Dave Shepard
The Sargeant is (well, will be in a few) in the mail. I used it on a couple of repairs to try it out, so you can say it was used to restore an 1801 Dutch barn. That and $2.50 will buy you most of a gallon of gas. :D It will need some more cleaning and fine tuning, but that is part of the final step in the plane owners journey, using a tool you've personally brought into perfect form. Well, that's my excuse anyway. The tote is cheesier than I remember, but I may have another. There are a few adjustments that will need fiddling with, like the cap iron and the frog location.
Do you ever make it out this end of the state? My workshop is about a mile and a half south of Timmy's place on the same road. I can show you the frames I'm working on if you make it out here.
Troublermaker
I got a question. I have got a bunch of old hand planes that I can no longer use due to health reason. All of them are in good shape. Is there some place that I can find what they are worth?
Jim_Rogers
Quote from: Troublermaker on October 15, 2010, 07:55:51 PM
We maybe interested in these tools to restore and offer for sale. Can you email me with some pictures of them?
Jim Rogers
Piston
Dave,
Not as much as I'd like to, but in 2 or 3 weeks I may be heading out to the Finger Lakes region of NY on a bike trip so maybe either on the way there or back I could check out some of your handy work ;D
I'll certainly look you up if I I'm out that way.
-Matt
Troublermaker
When I get tools together I try to post a picture.
Thank
Dave Shepard
Piston, did you get that plane, or are you out floating around in an ocean somewhere? :D
Piston
Dave,
Sorry for the super late reply.  yes and yes.  I did get the plane and thank you very much.  I had some time to mess around with it a little while but didn't get to tune it up as I was hoping.  I tried taking a 3 hour class at woodcraft on tuning old planes so I could learn what I need to but it didn't work out.
I am now back out floating around on the ocean as you suspected  :D
I need to get caught up on the forum as it's been a while since I've checked it.
Thanks again
-Matt
