Anyone try one of these?
Started by Mainah, March 02, 2011, 06:37:12 PM
Mainah
Hud-son makes a thing called a Boardmaster. Its a simple design. Has anyone used one before? Does it work or a waste of money? I'm not looking to mill anything huge or any hard wood.
Here's a link.  http://www.hud-son.com/includes/webboardmaster%20resized%20format%20picture.jpg
ladylake
 I'd look for  low cost bandsaw, chainsaw mills take a big kerf, cut slow, use a lot of fuel , are hard on saws which can add up to a lot of money in a hurry.  Steve
redbeard
I have one it works great for cross cut, I use it to square off ends on big beams mine fits on a 2x4 for a rail, I haven't tried it for ripping just crosscut.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
laffs
what are you looking to do with a mill. theres probably some good cs mills out there. when i was looking a chain saw mill never entered my mind.  i think there to slow for what i wanted. i  dont know what small push mills go for now,maybe check them out Thomas is local might even have used
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Carpenter
     I started with a thing like that.  My plan was just to cut some beams to build a timberframe.  It works just fine, but, it didn't take me long to realize that I needed a sawmill.
pasbuild
The only thing I used mine for is to cut rabbits into log walls to slip the wall paneling into during construction of interior walls.
If it can't be nailed or glued then screw it
Would be fine for remote rustic building and intermittant use but would grow old fast if you had to use it much. Frank C.
RPF2509
I've used something similar.  Good for edging boards or other thin pieces but it really slows down the thicker the wood gets. Can be good for the initial cut to get a flat side for an alaska mill but as others have said it can be really hard on a saw and hard on you.  May be the only option where you can't get a mill to but any where else a woodmizer type mill will out produce it by far and be more accurate.
Ironwood
Many, many times simple items like that, or Alaskan set ups can be easily made at home w/ some minimal skills and hardware, a welder doesn't hurt either. I shop at scrap yards for all sorts of stuff that cam be "re-purposed", I am a scavenger of the highest order :D
Ironwood
Meadows Miller
Ironwood four words Mate  ;) Rescue,Retool & Reuse  ;D 8) There is nothing wrong with that thinking its made some smart sawmillers alot of money over the years Mate  ;) ;D ;D 8) 8)
4TH Generation Timbergetter
