new land!
Started by lude791, August 31, 2011, 09:02:51 AM
lude791
morning everyone, i just bought a piece of land of 68 acres! very good price and all..... its located in quebec, canada
theres a nice mix of mature trees    (use to be a tree plantation, around 20 acres, 30 yrs ago)
so i have a few little questions:
1)  thinking/looking into buying a sawmill lt10-lt15, with an edgers/planer
so that i can start cutting to reduce the cost of building my house... is this a good idea? can i use the wood i cut to build legally?
is it a good idea?  im in no rush to build... since my savings went to buying the land. (btw it wouldnt be a log cabin)
does anyone have any suggestions on other equipment i could use/need?
money wise would it be a good idea?
any other suggestion will be greatly appreciated
Raider Bill
Congrats and welcome!!!
The guys with your answers will be along shortly ;)
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
You may want to check the local regulations, but I believe the lumber will have to be grade stamped because: 1) if it's financed it will probably have to be built to professional plans, which leads to 2) It will be required to be insured. Outside of that, I guess you take your chances. If you go it alone, don't mention a sawmill to the insurance people, because it will likely be followed by a whole lot of questions. Number 3) is maybe you can get the NLGA to grade your lumber, there will be a fee.
paul case
congrats on the new land purchase.  can you cut your own logs into lumber to build your house? i did. you better check the local regs but i bet you can as well. the framing lumber alone paid for my  mill. pc
pc
Jasperfield
Any time a person has  to question whether the wood he has sawn can be used to build his house, and so forth; There lies a real problem with his government, be it local or national.
Mooseherder
Yes, and we should make sure these laws get changed back around.
The insurance is just as bad as any law, and usually go hand in hand. My uncle had square Selkirk chimney and that wasn't good enough for the insurance, they wanted round. It's stuff like that, that is criminal. Not that a building should be made from material that makes the grade. ;)
jdonovan
Quote from: lude791 on August 31, 2011, 09:02:51 AM
Talk to a builder and see what the cost of dimensional lumber would be for the home you want to build. It may surprise you how little of a homes cost is 2x material.
Had a builder friend who was putting up a 3000 sq-ft home here in Virginia, and his dimensional cost was only about 20,000, on a $750,000 home. He did suggest that trim, molding, casements, sills, etc... there was quite a few feet of that type material and at a few bucks a foot it doesn't take too long to make some savings if you make it yourself.
Congrats on your land purchase and welcome to the forum.
Going to need something to get the logs out of the woods to the sawmill. Some do it with a ATV,I have a 4 wheel drive tractor with a loader, a skidder,skid steer,dozer. I would suggest some old steel roofing to cover up your lumber to dry it.Ever been around a sawmill before? Need to dry your lumber correctly.Meaning need a good foundation and sticker and stack it right. It's good you have the time to ask questions and plan your dream out.
park ranger
I would buy a skidder.  I bought the sawmill first and had no way to move stuff around.  I cleared my house site with a skidder, so much faster than digging stumps,  just push over trees and drag stuff around.  The logs are mostly lifted up and away from the dirt.  Then rent an excavator and dozer for the rest.  You can probably find a portable sawyer to come to the site and mill to see what you think.  Lots of the wood in my house is home sawed, the framing inspector said not to use it for floor joists or rafters but everything else was fine.  I would build a big shop first.
Al_Smith
Oh it most likely depends on where you are at as to  any regulations that must be followed .Where I'm at all they want is a permit so they know to tax you more .There are no real inspections .
As far as building ,the framing lumber is not where the big expense comes in it's more the finish materials .You can buy premium quality as oppossed to stuff with bark on all four corners and not raise the price that much .A lot nicer to work with too instead of sled runners that you save maybe 40 cents a 2 by 4 by 8 .That stuff would have served better had they chipped it for OSB .What you think you save in material cost will be over shadowed by frustration .
Welcome lude791, to the Forestry Forum.   :)
SPIKER
what about building a log cabin?   logs that range should make some verynice cabin material;)
mark
