timberjack 608 problems
Started by Dezert608, November 03, 2011, 02:01:54 PM
Dezert608
iv got a timberjack 608 with a quadco hot saw and im having hydraulic problems when the blade is on the right side track looses power and when i look in the back there are two ball valve where the hydraulic houses connected to them and when i switch them around i get full power to the tracks but the head doesn't work and i was curious on how can i find hydraulic schematics for the timberjack and quadco iv looked and called every where its like a needle in a hay stack
furltech
kiko
jdparts.com  Online parts cataloge will not have schematic but will have hydraulic installation whick should help you run down the problem.
