Jonsered 630 Super
Started by Yoopersaw, April 25, 2012, 11:13:30 AM
Yoopersaw
After sitting over the winter, my 630 wouldn't start last spring.  I tried everything I could think of and than bought a new 372XP.  I put the 630 on the shelf for another summer and winter.  Yesterday, I pulled the 630 out, dumped the gas into my recycle can for my weed eater, put in fresh gas and decided to start over.  On the 5th pull, it was running like new.  I have no idea why it wouldn't run last spring.  At least now I have a nice back up.
Al_Smith
The gas gets stale after it sits a while .It's a common problem with an easy fix .
Yoopersaw
I used fresh gas last year too.  I still have no idea why it wouldn't run last year.
Ward Barnes
Quote from: Yoopersaw on April 28, 2012, 11:04:19 AM
:D Maybe the saw was just lonesome and wanted another saw as a roommate.
My Stihl MS 390 gave me the same problem yesterday.  I pulled on the starter cord until my arm was sore, this after cutting and starting well all morning.  I walked away, rested a couple of minutes, and then gave it one pull and it ran like a champ.
As for a real answer perhaps someone can help us both.
God Bless, Ward and Mary.
7 year old Stihl MS 390.  New Stihl trim saw MS 250.  Kubota BX 2200 tractor.  2005 F150 4X4.
Dull chains cause accidents.  Accidents cause shorter life spans.
You don't sharpen a chain when it gets dull.  You sharpen a chain to keep it from getting dull.
lumberjack48
If i had to pull more than 4 times on a cold start or more than 1 time when hot something is wrong. Usually the low jet is a little to lean.
I would change gas filter an put a new plug in. If it still did it, i'd open the low jet [counter clockwise] turn just a little, 1/4 might be to much. After doing this you might have to turn the idle screw clockwise a little, so saw idles.
Al_Smith
Must be something in the air .I about pulled my arm out of the socket yesterday jerking the rope on a year old Stihl MS 660 .No go ,annoyed me to no end . >:(
shelbycharger400
my 630, sometimes is hard to start HOT,       i have to pull it about 6 or 7 times when havent been started for a few days.   Then again,  this one i have to put my foot in the handle, one hand on the front handle holding it down, then other hand to pull the cord.   Never had a saw like this , lots of compression/ power
