Strength loss of green post
Started by Woodman12, August 02, 2012, 03:00:45 PM
Woodman12
Quick question.  If i take a 10" diameter post directly off of the mill and put inside a house.  It will be load bearing.  I know that checking will occur, but will there be a significant loss of strength.  Is it possible to do this or should this idea be tossed out of the door.
Al_Smith
Well they took basically green oak and built those huge dairy barns about 100 years ago and loaded the mows full of hay if that tells you anything .If they kept a good roof on them they're still standing .If not they all fell down years ago .
Jim_Rogers
Quote from: Woodman12 on August 02, 2012, 03:00:45 PM
You will not loose any strength from the checks as they only go from to surface to the pith of the tree. And not all the way through which may let the post split in half.
The loss in strength is that a green post is not as strong as a dry post. Water in the green post will dry out and it will become stronger as it dries.
So if the size of your post is marginal to the load you want it to carry then you may want to either up-size the post a little, choose a stronger wood, or wait a year or two until it drys out some.
Jim Rogers
Woodman12
Thanks for your input Jim.  That is what I needed to hear.
Satamax
Woodman12.
If i may add, an oak post, 10"x10", 10' tall; can bear 30 metric tons. And iirc, that's with a safety margin of 6. So it takes 6 times that to colapse.
Take 83% of that for larch or slow growth pine, 66% for cheap fast growing pines.
canopy
Structural calculations are usually based on clear wood. Brace pockets and other joinery between the base and loaded surface need subtracted out. Grade of wood also needs considered.
